+ Reply to Thread
Results 1 to 4 of 4
Thread: Im looking for a Common Cathode 7 segment display !
  1. #1
    Giggabite Newbie
    Join Date
    Jan 2009
    Posts
    19
    Default Im looking for a Common Cathode 7 segment display !
    That operates at 12 volts . I have been looking everywhere for these and ive noticed they are not easy to find. Please help . I HAVE BEEN WORKING ON DESIGNING A LIGHT AND DARK SENSOR which when darkness falls , a relay operating at 12v will turn on an analogue 555 timer circuit . This timer will then trigger a lamp after 5 seconds. Ultimately, the pulses from the op amp will also feed into two chips a 4511 and 4510 bcd . These chips will then be connected to the common cathode 7 segment display . If anyone can assist in linking me up .
    thanks
  2. #2
    Chippie Excellent Chippie Excellent Chippie Excellent Chippie Excellent Chippie Excellent
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    Quote Originally Posted by Giggabite View Post
    thanks
    So why cant you design the cct so that the leds trun off a 5v supply?
    The 4511 will happily run from a 5v supply
    Eccentric millionaire financed by 'er indoors
  3. #3
    Giggabite Newbie
    Join Date
    Jan 2009
    Posts
    19
    Quote Originally Posted by Chippie View Post
    Im confused ...
  4. #4
    Join Date
    Mar 2003
    Location
    Good 'ole England
    Posts
    961
    Im confused ...
    I'm confused as to what you are trying to achieve here........Are you wanting to clock the displays so that each time it turns light/dark they count up?
    The 7seg displays are common cathode Yeah? ergo the 7 anodes are fed from the outputs of the driver chips...if the chips are fed with a 5 volts supply, the cathode end of the 7 seg display is then connected to ground....No 12 volt supply in sight...You will need a 5v reg to drop the 12v main supply to 5v using a 7805....Whats the problem?
    The attached drawing shows how to hook up a 7 seg display to a 4511.
    The 4 binary inputs will be replaced by your dec/binary counter....which in turn is triggered by the op amp?
+ Reply to Thread
  1. Common Anode SSD vs Common Cathode SSD
    By Gayan Soyza in forum Micro Controllers
    Latest: 1st March 2009, 08:23 PM
  2. Is it possible to use ULN2003 to drive a big common cathode 7-segment?
    By kevin_rimer in forum General Electronics Chat
    Latest: 19th August 2008, 05:39 PM
  3. 10v Common Cathode 7 segment LED Display
    By jon.was.here in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th May 2008, 08:06 PM
  4. LED Displays - Common Anode or Common Cathode?
    By mbu in forum General Electronics Chat
    Latest: 10th March 2007, 08:21 AM
  5. Common Cathode 7-Segment
    By Deathshead in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th February 2004, 11:22 PM
Tags for this Thread
