| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
Hi once again I am hoping for some help. In my other thread I was asking for help to obtain a BM2576 type switching regulator from a LCD TV I have a PCB removed from another set with the following chip on board. To make things simpler I enclose a Drawing of the chip. The chip is the same size and shape as the SMD BM2576 shown on the datasheet included with my other post. I know this means nothing I just thought you might like something for comparison. Thanking you again.
__________________ I think, therefore I am. Therefore I must be !!! I think ??? Last edited by rmn_tech; 14th March 2009 at 11:30 AM. | |
Thanks for your reply Hotwaterwizard. I have the Datasheet for the BM2576. However I don't know if this is an Equivalent or a completely different chip, as it is in the PSU section of a PCB from an unidentified LCD TV.
__________________ I think, therefore I am. Therefore I must be !!! I think ??? | |
That does not mean they are the same. Just the same case style.
Well after some research the SK means Sanken is the Manufacture of the IC and it could be a special application designed IC for the TV Manufacture. SANKEN ELECTRIC : ICs : SMPS Power ICs For Non-isolated SMPS(Custom) R.C.Chopper STR50000 Series There series of ICs are custom or application specific products Last edited by hotwaterwizard; 15th March 2009 at 07:57 PM. | |
| | #6 |
Ok if you need more help, Lets see if we can find a schematic of this LCD TV . What is the Manufacture, Model number, and Serial Number? | |
| | #7 |
Hi the TV is a Technosonic LCD5015 I have no diagram but I have found that there is a 4v square wave at the output of the BM2576 (I have now found out that this is also a LM2576 thanks to other forum members) However without the diagram I am not sure if the square wave is coming from the chip or is being superimposed on the 5v line from elseware. The set shows a picture for about 1 - 2 seconds then the picture dies The sound is not affected. There is a 5v feed to the backlight inverter board and this dies at the same time as the picture. This 5v supply is very noisy though not with a square wave. Thanks again for your interest.
| | #8 |
I take it that you had as much luck as me in finding a schematic for this set. ![]() No luck at all.
| | #9 |
| Your problem is not knowing what make the set actually is, Technosonic is just a badge on cheap crap, so you've no way of finding out who makes it.
| identify, smd |
| Might someone help me identify this? | InductorNoob | General Electronics Chat | 34 | 18th April 2009 01:30 PM |
| How to identify pin 1 on SOT-23 | Pommie | Micro Controllers | 23 | 1st September 2008 08:57 PM |
| help to identify | rahuljin | General Electronics Chat | 2 | 26th May 2008 02:53 PM |
| identify this | imgemini | General Electronics Chat | 6 | 17th August 2004 01:07 PM |
| Help Identify This? | rstark18 | General Electronics Chat | 10 | 8th August 2003 04:23 PM |
