Old 27th February 2009, 10:21 PM   #1
Default looking for linear actuator with return spring
I am looking for linear actuator with a return spring the retracts the shaft when power is interupted. The shaft travel only needs to be 5 inches and the actuator can be AC or DC. 15lbs or less of thrust should work for my application.
I am aware of rotory actuators with a return spring but that won't work for my application.
Thanks,
Jim
jimbo1212 is offline
Old 27th February 2009, 11:27 PM   #2
Have you thought about compressed air?
What about a solenoid?
Mike2545
Mike2545 is offline
Old 28th February 2009, 03:57 AM   #3
I did not want to deal with air.
Old 28th February 2009, 04:19 AM   #4
Is the speed that pneumatic cylinders travel, or don't you want to run a compressor?
If it's a speed issue you can run air over oil to get the speed just right.
Mike2545
Mike2545 is offline
Old 28th February 2009, 08:23 AM   #5
How fast? Is a lead screw permissible? I guess not, if a spring has to be able to return it on power interruption.
That's a pretty tall order for a solenoid or similar device. Can you consider a 75-lb pull (1" throw) solenoid with a 5:1 lever?
mneary is offline
Old 28th February 2009, 10:23 AM   #6
What country are you located in ?
picbits is online now
Old 28th February 2009, 04:32 PM   #7
With a DC motor driven linear actuator, you could have a backup battery...and a circuit to detect power failure, drive the actuator home, and shut down.
Ken
KMoffett is offline
Old 2nd March 2009, 03:57 AM   #8
I was hoping to avoid the pluming involved with using air plus having a supply of air. Electrical solenoids have been attempted previously by others with mixed results. The solenoids tended to burn-up over time when used with a level system due to either excessive resistance or jamming. My goal was to allow the spring to retract the shaft when power was interrupted.
Old 2nd March 2009, 04:01 AM   #9
Plumbing is not a real issue with these
John Guest 3/8" x 1/4" MPT Quick Connect Fitting - eBay (item 290026450742 end time Mar-23-09 07:52:12 PDT)
I guess the real problem would be the air thing, but probably the one I would choose.
Mike2545
Mike2545 is offline
actuator, linear, return, spring
Linear Actuator H_guy Electronic Projects Design/Ideas/Reviews 6 27th September 2008 08:58 PM
Driving Linear Actuator from PIC oferx Micro Controllers 7 10th April 2008 10:31 PM
Linear Actuator for Artist Bdoop21 General Electronics Chat 3 7th October 2007 10:02 PM
Potentiometer link to linear actuator dermotcaf Electronic Projects Design/Ideas/Reviews 5 22nd January 2007 12:11 PM
Need some other idea on miniature linear actuator mister_e Datasheet/Parts Requests 4 28th July 2006 07:57 PM
