Old 23rd February 2009, 11:46 PM   #1
Default looking for BJT that inludes protection diode.
I have a BJT that switches on & off a relay, and i couldnt find a low cost, not through hole, BJT with protection diode included.
Does anyone know about some?
Thank you.
Addition:
I forgot to mention that i'm interested in an NPN BJT.
Thanks.
alphadog is offline
Old 24th February 2009, 07:01 AM   #2
Check in Digikey for transistors, and sort on transistors, single bjt. Scroll to the right and find the selection for NPN+diode. (and check 'in-stock').
Looks like there are a few to choose from starting at 56 cents.
mneary is offline
Old 24th February 2009, 10:12 AM   #3
Thank you.
Everything thats on stock there is transistors array, not single.
alphadog is offline
Old 24th February 2009, 10:20 AM   #4
Why on earth do you want one?, protection diodes need to really go across the relay, NOT across the transistor - just use a separate diode across the relay.
Nigel Goodwin is online now
Old 24th February 2009, 02:18 PM   #5
Since it's probably for a 4 transistor h-bridge the diodes will work.
Bill
Smart Kits build Smart People
Old 24th February 2009, 03:17 PM   #6
Except he specified an NPN transistor (singular) and a relay.
Old 24th February 2009, 03:21 PM   #7
Ah yes, silly me thought it was a continuation of the latching coil thread.
Bill
Old 24th February 2009, 09:17 PM   #8
I have a question please, not related to BJT and relay.
I found a N-channel MOSFET that has a diode across its Drain-Source channel.
If the VGS is lower than VTO, then IDS should be zero and therefore VDS becomes VCC (assuming its source's connected to VCC).
In my case, VCC = 5V which is larger than the VF of the Drain-Source diode.
How come the diode doesnt start coduncting current and therefore increasing IDS from 0A to IF of the diode?
Thanks.
alphadog is offline
Old 24th February 2009, 10:39 PM   #9
Because the diode is reverse biased.
mneary is offline
Old 24th February 2009, 11:33 PM   #10
Thats the thing, the anode is connected to drain, not to source, so its forward biased.
Take a look please:
alphadog is offline
Old 25th February 2009, 01:38 AM   #11
That's a dual transistor, one N-channel and the other P-channel. The drain of the P-channel device (Q2) is connected to the anode of its diode.
The drain of the N-channel device (Q1) is connected to the cathode of its diode.
mneary is offline
bjt, diode, inludes, protection
Reverse Protection Diode krich General Electronics Chat 5 7th January 2009 12:10 AM
Do I need a Protection Diode for 78L05? Suraj143 General Electronics Chat 2 7th December 2007 06:05 AM
Relay protection with diode. bananasiong Electronic Projects Design/Ideas/Reviews 20 20th April 2007 03:50 AM
PIC ADC diode protection ptewright Electronic Projects Design/Ideas/Reviews 8 22nd June 2006 09:56 PM
Protection diode Scarr General Electronics Chat 5 16th December 2005 01:14 AM
