| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
dear friends any one tell me how to reduce power consumption of fan [ draw 50 watt make to reduce ] watt any circuits is there pls reply thanks krishnainfotech@gmail.com | |
Install a switch and turn it to the off position. That will reduce the power consumption.
__________________ Mike2545 | |
Reducing the RPM of the fan will likely reduce the power consumption. How you do that electronically, depends on the type of fan motor. You might also shorten the blades keeping balance in mind.
__________________ stevez | |
if the fan has a separate switch on the wall you can use a dimmer switch. but the fan should have its own speed control. if not then you can just add a high watt resistor in series with the fan. Btw i only joined this forum to answer that question. :P
| ceiling, consumption, current, fan, reduce |
| Current Consumption by CCD Cameras (Spy Cams) | Electrix | General Electronics Chat | 0 | 6th September 2005 06:06 PM |
| down light (ceiling) | mahinda jayasinghe | General Electronics Chat | 4 | 14th May 2005 08:44 AM |
| 12v automotive relay current consumption, HOT | RaG | Electronic Projects Design/Ideas/Reviews | 7 | 18th March 2005 08:26 AM |
| Current consumption meter | Scarr | General Electronics Chat | 12 | 15th December 2004 07:49 PM |
| How to reduce current? | Lac | General Electronics Chat | 13 | 18th June 2004 09:30 PM |
