+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 28
Thread: high power latching relay
  1. #1
    carmusic Newbie
    Join Date
    Jun 2006
    Posts
    104
    Default high power latching relay
    Hi i try to find on internet for a latching relay for 100A and 100V DC resistive loads, all the ones i found are at 28V dc max
    If you found something even if it is from china i would be very interested
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    A Digikey search found some but they're not latching and are $230.
    Bill
    Smart Kits build Smart People
  3. #3
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    Quote Originally Posted by carmusic View Post
    You may have more luck looking for relays that have extra auxilary contacts and wire them in as a latching circuit. Not sure how much luck you are going to have finding 100amp DC rated contacts. Also what coil voltage are you requiring? Probably more information about what you are actually controlling and how it needs to operate (how will relay be turned on and turned off) might help us find you alternate solutions.
    Lefty
    Measurement changes behavior
  4. #4
    carmusic Newbie
    Join Date
    Jun 2006
    Posts
    104
    coil contact should be 24vdc or 12vdc i am controlling big transformers Rectifiers that outputs 100Vdc 100A maximum for cathodic protection
    i have found a lot of 200A latching relays but always 30Vdc max
  5. #5
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    What are you switching that has a 10,000W load like that?
    Bill
  6. #6
    carmusic Newbie
    Join Date
    Jun 2006
    Posts
    104
    it is use to cut power for cathodic protection of pipelines
    would it be possible to make this with mosfet since it is a resistive load. the reverse diode in mosfet will make troubles i think since i must have no polarity (must work in both ways and don't want the diode to conduct)
  7. #7
    user_88 Newbie
    Join Date
    Nov 2008
    Location
    Texas
    Posts
    415
    Here is a 200V DC @ 200 A DC relay:
    DC Power Relays G9EC-1 | OMRON Electronic Components Web
    It might be a good idea to include a safety factor on your current and voltage ratings.
    As mentioned above, you would have to devise an appropriate latching scheme.
    Maybe just get a smaller latching signal relay to energize the main relay coil.... shouldn't be a problem.
  8. #8
    carmusic Newbie
    Join Date
    Jun 2006
    Posts
    104
    thanx i had found those but they are over 300$ each!!!
  9. #9
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    Yep, maybe you can find some used ones on eBay. A 10kW anything will not be cheap.
    Bill
  10. #10
    hotwaterwizard Excellent hotwaterwizard Excellent hotwaterwizard Excellent hotwaterwizard Excellent
    Join Date
    Apr 2004
    Location
    California USA
    Posts
    992
    Big Amps cost Big Bucks!
    What is your coil voltage?
    Here is a 12v Power Relay for $6.50
    12 VDC POWER SOLENOID | AllElectronics.com
    John DeRosa (Hotwaterwizard)
    hotwaterwizard@aol.com
  11. #11
    Join Date
    Mar 2007
    Location
    Posts
    1,420
    Quote Originally Posted by hotwaterwizard View Post
    However it has a limitation: "50% duty cycle. 10 seconds on. "
    It's designed to start a car engine, not for continuous operation.
    Lefty
  12. #12
    user_88 Newbie
    Join Date
    Nov 2008
    Location
    Texas
    Posts
    415
    Default IGBTs
    This page from a vendor says that their IGBTs can be used in parallel for higher current applications.
    Would it be possible to arrange something that would accommodate your requirement for current in both directions?
    International Rectifier - Product Information
    Here is one item that appears to be adequate for 30A DC ....
    https://ec.irf.com/v6/en/US/adirect/...D=IRGP50B60PD1
    If the costs are acceptable, obtain several and see if they actually do what you want.
    Maybe the company will give you some samples ....
  13. #13
    user_88 Newbie
    Join Date
    Nov 2008
    Location
    Texas
    Posts
    415
    Default Power Switching in the Real World
    There is an upcoming article about power switching using FETs and IGBTs in the January 2009 issue of Circuit Cellar Magazine.
    The author says that his experience with paralleling IGBTs for higher current applications exhibits some unequal current sharing in such an application. ....with some units becoming hotter than others... and that he prefers FETs for parallel current usage.
    It may be that the IGBT parts that are available at this time have improved, and would be worth a trial, or some sort of actual test before you reject their usage.... particularly if they are free samples.
    There is supposed to be a follow up article in the CC magazine in February... regarding practical Power Switching cookbook circuits.
  14. #14
    carmusic Newbie
    Join Date
    Jun 2006
    Posts
    104
    if i do a switch with about 10 mosfet in parallel, could it work? will the current be share (i will take all similar mosfet with same rds)
    can i put them back to back to make a swtich with no polarity?
    if it is possible even with 20 mosfet it would be still be less expensive than a mechanical relay (minimum 200$ for a good one!)
  15. #15
    user_88 Newbie
    Join Date
    Nov 2008
    Location
    Texas
    Posts
    415
    What I was thinking was to try one bank of 5 or so, with a common gate signal, to be used for one direction of current, and a separate bank of the same number, in parallel, to be used for the opposite current direction. Then you have to think of some way to trigger each respective gate signal, when it is required. ....Not exactly sure how to do this .... maybe zero in on one or other side of the AC line polarity....
    I don't think a back-to-back series arrangement would work. However, it looks like the IGBT specifications are robust enough to stand up to whatever is required .... just a matter of getting the gate signals to fire when you want them to....
    ... Are you thinking Mosfet or IGBT?
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. bi-stable latching relay?
    By wsemajb in forum General Electronics Chat
    Latest: 3rd June 2008, 11:32 PM
  2. pcb relay high power
    By carmusic in forum Datasheet/Parts Requests
    Latest: 17th May 2008, 11:01 AM
  3. What is a latching relay vers a non latching relay
    By MrDEB in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd November 2007, 01:44 PM
  4. Looking for pre-built 12 volt momentary latching relay
    By Louis Cypher in forum General Electronics Chat
    Latest: 2nd December 2006, 07:31 PM
  5. Wiring a latching relay
    By behrendfry in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th January 2006, 05:00 PM
Tags for this Thread
