+ Reply to Thread
Results 1 to 6 of 6
Thread: SMD to Through hole
  1. #1
    AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,585
    SMD to Through hole
    Im looking for some parts. The originals are SMD parts and im looking for the equivalent through hole devices.
    NDS352AP :
    * MOSFET
    * Transistor Type:MOSFET
    * Transistor Polarity:P Channel
    * Drain Source Voltage, Vds:-30V
    * Continuous Drain Current, Id:2A
    * On Resistance, Rds(on):80mohm
    * Rds(on) Test Voltage, Vgs:-10V
    * Drain-Source Breakdown Voltage:-30V RoHS Compliant: Yes
    MICROCHIP TC77:
    * Temperature Sensor IC
    * Termination:SMD
    * Package/Case:5-SOT-23
    * No. of Pins:5
    * Leaded Process Compatible:No
    * Operating Temp. Min:-55°C
    * Peak Reflow Compatible (260 C):No
    * Reel Quantity:3000
    * Supply Voltage:3.3V RoHS Compliant: Yes
    So far those 2 are SMD and need the same but in through hole. Any help? Thanks.
  2. #2
    picasm Good picasm Good
    Join Date
    Sep 2006
    Location
    UK
    Posts
    358
    They don't do a TC77 through hole option but Microchip direct have a "demo board" option which allows easy connection to it:
    TC77 Thermal Sensor PICtail Demo Board
    A TC74 is available in a 5 lead TO220 package but it uses the 12C protocol instead of SPI
  3. #3
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,585
    Wow i rather use the SMD part that a 10:1 price. I can get the TC77 for $1. I rather buy the SMD (at least 5 then lol)
    I found they have it in 8Pin SOIC also. Ill get that since its bigger.
  4. #4
    3v0
    3v0 is online now
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,399
    Blog Entries
    11
    There are many parts that are either only avialable in SMD or are much cheaper in SMD.
    For a long time I resisted using SMD parts. In some ways it is better. There are so few holes in most projects you can drill them by hand with a pin vice. As a hobby person I feel free to mix through hole and SMD parts.
    I would rather install a through hole resistor then solder on a SMD resistor and a jumper. I am thinking 1/8 watt.
    I have a good supply of TO-92 regulators so I use them. That sort of thing.
    3v0
    BCHS/3v0's Tutorials
  5. #5
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,585
    The issue is that since im not making custom boards as of yet its hard to do some SMD devices. I have in the past split the wholes on a pref board and used it for a smd part and worked fine but its a hassle. I might order some of those nice boards from dip micro but until i can get my laser printer im stuck.
    But i would love to solder some smd parts if the board is ready. I would also mix and match with through hole as you say because i would save on drilling.
    Ill go smd here i guess. Thanks!
  6. #6
    BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent
    Join Date
    Dec 2005
    Location
    Vancouver Canada
    Posts
    1,186
+ Reply to Thread
Tags for this Thread
