+ Reply to Thread
Results 1 to 7 of 7
Thread: switch that stays closed for a specified time period
  1. #1
    marchache Newbie
    Join Date
    Mar 2004
    Posts
    25
    Default switch that stays closed for a specified time period
    What I am looking for is a switch that when pressed stays closed for x seconds and then opens. For a 1.5-9V circuit.
    Does such an animal exist ?
    Marc
  2. #2
    Sebi Newbie
    Join Date
    Jan 2003
    Location
    Hungary
    Posts
    1,717
    This circuit called monostable multivibrator.
  3. #3
    Johnson777717 Newbie
    Join Date
    Nov 2003
    Location
    Phoenix, Arizona
    Posts
    495
    you could also rig a 555 timer circuit with a couple transistors.
  4. #4
    marchache Newbie
    Join Date
    Mar 2004
    Posts
    25
    Default Switch question
    Thanks, I figured I could use the 555 but I'm really trying to keep this as simple as possible (maybe the 555 is ?)
    Basic idea is simliar to the timer on a washing machine. Turn it to the desired time, push the switch and circuit is closed for that duration.
    Same idea just much smaller and only need run for 10s or so.
    But...if a switch like this doesn't exist then it doesn't exist.
    In that case, having not yet played with the 555, a couple of questions:
    -Do I need to hold pin 2 high (1/3V) or is that done internally ?
    -What is the best (simplest) way to generate the trigger pulse? I'm assuming a momentary contact switch but how to I make the pulse negative ?
    Thanks for bearing with me. I'm new to this stuff.
    Marc
  5. #5
    marchache Newbie
    Join Date
    Mar 2004
    Posts
    25
    Just saw another post in the general discussion group that may answer my question on the 555. He has a n.o. momentary contact switch connected between pin 2 and ground. Would this work ?
    Follow on question: Does the circuit consume power at all between timing pulses (i.e after output goes low) ?
    Marc
  6. #6
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Default Re: Switch question
    Quote Originally Posted by marchache
    If you have a look at http://www.uoguelph.ca/~antoon/gadgets/555/555.html it contains a really good 555 tutorial.
    Yes, it will consume power at all times, there are various ways to reduce power consumption - one way would be to use a PIC microcontroller, putting it in 'sleep mode' to minimise consumption, and using the 'wake up on pin change' feature. But that's probably getting too difficult for you, a CMOS version of the 555 would reduce consumption considerably, and could be worth a try.
  7. #7
    marchache Newbie
    Join Date
    Mar 2004
    Posts
    25
    Thanks Nigel. That is an excellent tutorial!
    I figured as much. For this particular application I'll just put in a switch to turn on power to the 555
    Marc
+ Reply to Thread
Tags for this Thread
