| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
I am looking for a data sheet on a TO-220 part out of my Fi-Shock electric fence charger which is shorted. The part markings are: 8193 26 NEC K A G | |
Sounds like a SCR because of the KAG. Might just have to sub something unless the HotWaterWizard comes up with the datasheet for you. What is the voltage and current rating of the charger? Can you post a clear picture of the component?
__________________ Inside every little problem, is a big problem trying to get out. | |
this is all I could find for now. NEC. 8193. 6 A, 400 V | |
| | #4 | |
Input voltage to the charger is 120Vac, not sure on input current. Output voltage for fence chargers is generally ~ 4.0KV and is pulsed on & off. Output of this part goes through a step up transformer. Date written on charger PCB was 08/1989 Last edited by lewija62; 11th September 2008 at 01:36 PM. | ||
How about a picture front and back of the Circuit board. Make and Model number of the Charger would help too. | |
| | #6 |
Looking for the schematic I came across These goodies Website http://www.fishock.com/customerSupport/manuals.htm Owners Manual http://www.fishock.com/customerSuppo.../Energizer.pdf Installation Manual http://www.fishock.com/customerSuppo...e%20Manual.pdf | |
| | #7 |
Hi all. New to this forum, so apologies if it seems I am hijacking this thread, but it is on a very similar note. I am try to repair a Fi-shock 2000e fence energiser(The PCB shown is a working one) I am trying to assertain what part this is. It is the part in the top right, below the mounting hole, next to a thyrister (BT151-650R, 7.5A, 650v). I am thinking it may be a Zenner diode(On PCB it is D8). Can anyone help me identify it and what part number please. Sorry for the quality of the pictures. Thanks | |
| | #8 |
I can't see zip in the pictures, you need a LOT more light. It could be a zener or a small signal diode the picture isn't clear enough to tell. Can you get a much better pictures? You need a LOT more light to be closer and to focus it better.
| | #9 |
Sorry about the pictures, they were taken with my mobile. I will try again or leave until the morning Thanks | |
| | #10 |
Tried to get better pics, but sorry, don’t seem to work. Last time I did any of this was over 35 years ago, so, please bear with me. From the pic, these are the components R1 10 Ω R2 470Ω R3 2.2kΩ R4 470Ω R5 470Ω R6 10kΩ R7 1300kΩ R9 47Ω C1 473k 250v C2 100µf 50v C3 474k 600v C4 473k 600v C5 305k 600v C6 22µf 50v Q1 D45H11 pnp Q2 TP32c pnp SCR BT151-650r 7.5A, 650v Thyristor Thanks again for looking. All the rest are diodes, which I cannot make out. It is D8 that I cannot understand. It is glass, orange or gold with either a gap or silver line across the centre. | |
| | #11 |
Without a view of the underside, I'd say that diode D8 is a silicon diode like a 1N54XX-series, attached to the SCR "G" terminal as a clamping diode. The SCR is not heatsinked, so I assume that a small current is present in this circuit.
| | #12 |
| Thanks Shokjok. Here is a better picture of the underside.
| | #13 |
Never thought it would happen, but got a full schematic and parts list from Fi-Shock. The part in question is a BILATERAL DIAC (HT-40), whatever that means. So, Many thanks to all who helped. Is there anywhere this schematic and parts list can be saved on the site for future reference for others? It's in PDF format. | |
| | #14 |
Diacs are bidirectional diodes. If you want to save the PDF just start a new thread in the parts/data sheet request forum with an appropriate topic and upload the PDF as an attachment. It'll be there pretty much forever.
| | #15 |
8A/600V SCR S6008 S6008 | S6008 | Electronic Part Search http://www.littelfuse.com/data/en/Data_Sheets/E6SCR.pdf DigiKey, Mouser, and Newark have them in stock | |
| data, nec, sheet |
| data sheet | avinaik | Datasheet/Parts Requests | 4 | 29th March 2007 04:06 AM |
| old ic data sheet | paul(nc) | Datasheet/Parts Requests | 3 | 15th December 2006 06:03 AM |
| Need Data Sheet For LCD | dde2004 | Datasheet/Parts Requests | 5 | 2nd July 2004 09:11 AM |
| need data sheet on.. | Bruce L Williamas | Datasheet/Parts Requests | 2 | 4th October 2003 07:18 AM |
| Data sheet | srfr | General Electronics Chat | 2 | 11th March 2003 09:34 PM |
