Old 22nd June 2008, 01:10 AM   (permalink)
Default Low current equivalent for L298H
Hi All,
I have to cycle a coil (clock drive) with reversed polarity using an MCU. A full H-bridge would do the job.
However, the L298H is made for currents up to 2.5A, whereas the coil's current is 100mA max.
Is there any equivalent H-bridge which would suit the need for low current?
Thank you
Boncuk
Boncuk is offline
Old 22nd June 2008, 09:28 AM   (permalink)
You could go all discrete - a pair of PNP and NPN transistors do the job nicely.
If your coil is over 5v then I'd advise using another NPN on each PNP transistor base to stop any high voltages going into your driver IC.
If you want an "all in one" solution then have a look here - ST do some great drivers in 16 pin DIP and are another company I like dealing with. In fact I've had such good service from them that I deliberately choose their products over others even if they do cost slightly more.
STMicroelectronics | Dual H - Bridge [13]
picbits is offline
Old 22nd June 2008, 12:27 PM   (permalink)
Default Equivalent for L298
Hi picbits,
thanks for your help.
I like ST components also, but I found a very easy to handle single H-bridge driver at Toshiba Semiconductors.
The type is TA7291 and it is available in three different packages, where the 9pin SIL-package is not much bigger than a resistor array. It can handle 400mA continously and peaks of 1A at a maximum of 25V.
It seems to be ideal for the purpose I want to use it. (6V at 100mA)
The control circuit is extremely easy to wire: two input pins. one high means on (reverse inputs for reverse action), two low means stop, and two high means brake.
Regards
Hans
Boncuk is offline
Measuring current with current probe naseeam General Electronics Chat 1 19th July 2007 09:59 PM
ic equivalent or circuit equivalent bidex Datasheet/Parts Requests 2 5th October 2006 09:13 AM
human body feels DC current or AC current ? waheeda General Electronics Chat 13 22nd September 2005 10:17 PM
Will current Mirror circuit deliver constant current to LED? Haru General Electronics Chat 10 14th April 2005 11:07 AM
Low current power supply from stored current. McGuinn Electronic Projects Design/Ideas/Reviews 12 20th January 2004 07:15 AM
