| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
I have bunch of SMD LED's (mostly green and red, few white and few blue ones).. some are 0.6 some 0.8mm
The problem I have is, I have no idea what the voltage dropout is for those, what is the optimal and what is the maximal forward current, how long I can drive them with maximal forward curent .. etc etc .. Is there any way to measure this values (Vf I can probably measure with voltmeter but how to know optimal forward current) ? Is there "standard" for SMD LED's or trial & error is the only way to go?
http://www.it4um.com |
With out looking most small LEDs use a maximum of 20mA.
Go to digikey.com Part number search window type in “LEDs” Page down to Optoelectronics and click on LEDs -<75mA You can select which type of LED to look for. Under Package/Case I selected 0805 just to pick a small SMT type. Click on Apply Filter. I selected RED and Applied the Filter and now there are only 137 red 0805 LEDs. To get to a data sheet faster I chose the Manufacture of Rohm. At this point it looks like a RED LED needs 1.7 to 2 volts with a maximum of 20mA. Select a part-number. Select Datasheets. Now I see a datasheet for a series of Rohm LEDs in a small SMT case. |
thankx, I'll try
But it would be safe to try at 60% or so of the max current
this would increase the LED life. If I were to do it I don't feed more than 10mA
Regards, Sarma. |
The shorter the wavelength the colour the higher the forward voltage will be.
Red will be between 1.7 to 2V. Green will be between 2 to 3.3V depending on whether it's a blueish green or yellowish green. Blue and white will be from 3 to 3.6V. The forward voltage also varies depending on the current, for example a red LED might have a Vf of just 1.6V at 500ľA and 1.9V at 20mA.
| LED's | Tresguey | Electronic Projects Design/Ideas/Reviews | 7 | 16th September 2005 03:25 AM |
| Need Help With LED's | guillermo | Electronic Projects Design/Ideas/Reviews | 2 | 27th June 2005 03:32 AM |
| High Power IR LED's and Ultrabright LED's | Gandledorf | Datasheet/Parts Requests | 3 | 4th February 2004 02:12 AM |
| 100 LED's | adams2003 | Electronic Projects Design/Ideas/Reviews | 7 | 17th October 2003 04:19 PM |
| LED's? | LifeForce4 | General Electronics Chat | 1 | 21st September 2003 08:59 PM |
