Hi all,
I would like to ask the following, since it is the harder part for me to understand... I only have electronics as a hobby. I am doing a clock, and want it to be very precise, at many temperatures actually from -5c to +45c.
This is what I need to do:
Part A of project:
1 second timer circuit of which must use the TLC555IP
the output will be going to a 74ls192 decade counter.
What components would make very accurate 1sec pulse for the clock?
The place that I wil be buying my components (caps & resistors) from is Jaycar
Jaycar Electronics
They have MKT miniature Polyester, greencap polyester or mylar, Tag tantalum, ceramic, monolithic blue chip.
The TLC has different requirements than the normal 555 in the selection of components.
Part B of project:
somehow to use a 555 as a flip-flop so it can handle the multiplexing needed for some alpha numeric displays that I am expecting. how can it be used to be giving (or sinking in my case, since it is a common cathode) to be alternating the character.
here is a link for the segment display that I will be using.
Dual led alphanumeric display
or a very common multiplexer or a flip-flop ic commonly found would do too, but I have those handy(the 555's) same as the TLC, but the SA555 can source / sink 200mA but the TLC555 on the other can only do these:
* Sink 100 mA Typ
* Source 10 mA Typ.
Btw, I also have another timing circuit with a crystal (32.768Khz and a 4060...) but I really want to do it with the TLC555 since I want to make it "simpler" for me to do, since I would like to use what I have mostly at hand.
I also have a few '556's to use for the displays power. I think that will make it less 555's ;-)
Thank you to all that will help me.
