Old 17th May 2008, 03:48 AM   (permalink)
Default A simple freakin' ICSP cable!
I scoured Sparkfun, and Jameco, and Digikey, but no one seems to carry a simple PIC ICSP cable! What's the dilly, yo? Links or websites where I can buy one are greatly appreciated.
Buy it, use it, break it, fix it, trash it, change it, mail upgrade it, charge it, point it, zoom it, press it, snap it, work it, quick erase it, write it, cut it, paste it, save it, load it, check it, quick rewrite it, plug it, play it, burn it, rip it, drag and drop it, zip unzip it.
ArtemisGoldfish is offline
Old 17th May 2008, 04:01 AM   (permalink)
Microchip RJ12 or 2x5 IDC like mine or 1x6 ?
Bill
Smart Kits build Smart People
ICSP cables come in several flavors. Which one are you looking for?
3v0 is offline
Old 17th May 2008, 04:08 AM   (permalink)
1x6, it's what's on my serial cheap-o JVR.
Old 17th May 2008, 09:59 AM   (permalink)
Buy some 0.1 pitch header pins, and solder and heatshrink some multi-core wire on them. (pins on both ends, obviously! ) Works a treat, and is cheap.
zanes is offline
Old 17th May 2008, 02:34 PM   (permalink)
Here's a typical header to ribbon cable.
Bill
Old 17th May 2008, 03:17 PM   (permalink)
What I do on my one row headers, is to solder the short ends together (two strips together with shorties on the inside) and solder them. I then have 2 long leads on both side to use. Works great with the 2x5 header.
Krumlink is offline
Old 17th May 2008, 03:24 PM   (permalink)
Blueroom, did you make those cables yourself? If so, any tips for stripping the ribbon cable? Last time I tried it went nowhere, and messed up!
Edit: The reason I suggested pins on both end is that I use a PICkit 2, and breadboard. Other systems, obviously, will need different connectors. Principle is the same, it's quick, easy n' cheap!
zanes is offline
Old 17th May 2008, 03:27 PM   (permalink)
Those cables came with my Hobbyscope but I've made them before.
PC USB Oscilloscope / Logic Analyzer for $169.50 (UART, SPI, I2C, 1-Wire)
Bill
Old 17th May 2008, 04:07 PM   (permalink)
Zanes,
I think Spency's Tutorials (by Gramo on Electro-Tech) included a video tutorial about making cables (perhaps not ICSP, but same idea)-- he used ribbon cable, so perhaps you can pick up the technique:
Spency's digital-diy PIC micro Tutorial - Video Tutorials
Look for the "DIY - Polarized Headers and Straight Header Leads (7 Minutes)"
-Omar
Omar.M is offline
Old 17th May 2008, 05:38 PM   (permalink)
Cheers Omar, just what I needed. Don't know whether I'll ever use it, but it's good to have the knowledge!
zanes is offline
Old 18th May 2008, 11:08 AM   (permalink)
What do you know, it helped someone
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
PGD PGC Crosstalk 3v0 Micro Controllers 25 15th April 2008 09:09 AM
convert joystick usp cable 2 serial cable morabet General Electronics Chat 15 15th November 2007 11:39 AM
Simple project: audio cable tester (assistance needed) Pixie Electronic Projects Design/Ideas/Reviews 1 29th September 2005 07:32 PM
Serial Cable Problem ElectroGeek_87 Micro Controllers 4 13th August 2003 10:47 AM
simple help.. Making a simple amplifier. pls help urgent. paulbostaph General Electronics Chat 19 20th May 2003 04:32 PM
