Old 16th May 2008, 04:53 PM   (permalink)
Default Replacement LCD
I've been asked to help find a replacement for an LCD MOdule that is going to be obsoleted, but I'm having a huge amount of trouble hunting through LCD manufacturers and LCDs since they are so varied and so many and I don't know much about them.
Does anyone know of a possible replacement for the Tianma TM9632ACIWG?
Drop-in would be fanastic, but as it stands the most important things are a compatible pinout and same controller:
Controller: S6B0715A11-B0CZ (KS0715UM-H0CC)
20-pin FPC connector (pinout is in the attached datasheet
Dimension is also important since we want to make minimal hardware and mechanical changes, but I've yet to find another LCD that even meets the above two specs.
NO, that picture isn't me so don't bother asking if we can be friends.
Old 18th May 2008, 05:35 PM   (permalink)
Well just skimming over the datasheet, you need a 96x32 pixel, positive, transflective, FSTN 'custom' LCD. *Custom* because of the custom characters at the top. Serial interface, requiring external caps for the Vboost.
I don't think you're going to have much luck there mate. I only have a couple of suggestions.
1) Get onto a generic LCD manufacturer (topway, or another one form china) and send them the specs to get them to start manufacturing it. Very expensive and only worth it if you need LOTS of them.
2) Use a generic 132x32 graphic LCD, with an external micro to translate the serial commands/data from the original LCD's cammand set, to the new LCD's command set. The micro could also generate the 'custom symbols', altohugh they would be in dot-matrix format and so not be as clear.
There are 96x32 LCD's, but 132x32 or 120x32 is more common. As for 'FSTN' (black pixels instead of the horrid STN blue/grey) I'm pretty sure they are available.
Manufacturers would include:
BATRON
EVERBOUQUET
TOPWAY
Getting the same dimension will also be tricky, COG design is mandatory. But an 'adapter board' with the micro could be made <2mm thick and attach to the back.
Sorry for the bad news, but that is just my opinion. There are loads of special custom LCD's about, but the fact yours is one just makes it even harder to find a suitable replacement.
Blueteeth
Inconsistency is the key to flexibility!
Blueteeth is offline   Reply With Quote
Old 18th May 2008, 06:23 PM   (permalink)
What about contacting Tianma directly?
As said, it's a custom panel, you'll either need to strip them out of whatever you got it from or order scads of them.
Bill
Smart Kits build Smart People
LCD Madness jimi252 Micro Controllers 20 5th May 2008 08:44 AM
LCD 2x16 Demo for the Unicorn (18F4550) blueroomelectronics Micro Controllers 20 11th April 2008 08:08 PM
LCD Bargraph (fuel gauge) karenhornby Micro Controllers 10 10th April 2008 05:19 PM
Atmel, assembly:displaying on lcd Haidy Micro Controllers 13 11th February 2008 08:12 PM
PIC16F628A LCD problems. HerbertMunch Micro Controllers 17 2nd October 2007 09:19 AM
