| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
| Experienced Member | Hi, question .. some time ago I used to develop some hw with 8086 / 80186 CPU .. but, now I wonder if there is something "in between" CPU and MCU... to be more to the point, does microchip (or someone else) makes IC that - has some basic MCU functions (AD/USART/I2C/SPI) - do *not* have internal EPROM/RAM but uses external EPROM and RAM modules for "work" for e.g. if I have a project that will require 64MB of "code" and 128MB of RAM to execute, low cpu usage (so it can be slow), and need to communicate with periferials via I2C/SPI in "old days" I would have to put CPU + EEPROM + RAM for the cpu operation, on top of that I would have to make "port mapers" that will occupy address space and that way I would communicate with periferials, now, is there something in between ? (some small amount of internally mapped memory that is 1 8bit port with hw usart/spi/i2c and address/data lines for the rest of it) ?
__________________ http://www.it4um.com |
| Experienced Member | hi, The Z84C90 plcc device has a number peripheral functions and its compatible with the 8bit 8080/Z80 series of CPU [central processing unit] The Z8 has some of these features
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's: www.winpicprog.co.uk/ Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 14th May 2008 at 12:52 PM. |
| Experienced Member | Quote:
Ah my old friend zilog, I was hoping microchip had something (as I have microchip distributor in the neighborhood ) but I'll see what will suit my hobby better
__________________ http://www.it4um.com | |
| Experienced Member | Hi. Atmel and Philips make a line of processors that have a loooong list of capabilities. However, you can forget about 64/128MB of code and data space. You can reallistically expect 4kB to 128kB, with one series (Philip's P89c66x) capable of 8MB of external code and 8MB of external data space. Go to DigiKey(.com) and type "8051 adc uart" into their search window. Then get a cup of coffee and settle in for a long read through the data base. You should get something like 800 to a 1000 hits back. I say 8051 because that is what my employer had me look for recently. There is still lots of free code and several tools out there for this venerable old line from Intel. looks like everybody else picked up on this chip while Intel lost interest in it. Add "flash" to the search and the list gets shorter, but this gives you code memory you can program over and over. If you want lots of peripherals on the cheap ($2.46 for 8kB of code space/$2.64 for 16kB) check out the Philips 89LPC952/954 at DigiKey. This thing has more goodies stuffed in it than a Thanksgiving turkey. And there are plenty of Atmel 89C-series chips (and others) with FLASH available in a DIP40 package, with 4k to 32k of code space. Great for breadboarding. And I'm sure Microchip has their lineup as well. End $.02. kenjj
__________________ All my pencils *used* to have erasers! |
| Experienced Member | thanks kjennejohn, thing is, for now, I'm pretty satisfied with pic's .. collected data is stored on a MMC card and later used on PC... but for some ideas I have (to do with object recognition) I need to do a lot of matrix calculation and that requires RAM .. lot of it .. adding a bunch of unoptimized code lead to "I need many MB for program and many MB for RAM" thanks for the pointers .. I will go trough the list and check out the tools I can get and properties they have (hence level of amusement) and check out if I do or do not want to enter into some project with those
| New Member | I know some of the 18f series pics have an external memory interface although I'm not sure if they can address as much memory as you want.. check out the datasheet of 18fx8xxx. |
