| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
I never used this MCP6001U (just saw the ds for it few minutes ago first time in my life), is there any "expert" that can tell me can I replace it with simple 741? EDIT: more info - I'm using it to oscilate mosfet to pull up the voltage from 5 to 14V so nothing "smart/sensitive"
http://www.it4um.com Last edited by arhi; 12th May 2008 at 04:25 PM. |
A lousy old 741 opamp is 40 years old. It is designed for low frequencies because its max frequency for full output is only 9kHz. It is designed for a 30V supply. Its inputs and outputs don't work when they are within about 3V from a positive or negative supply voltage.
The MCP6001 is designed for a 1.8V to 6.0V supply. It produces full output up to 30kHz. Its inputs work fine at either supply voltage and when the load current is low the outputs go to either supply voltage.
Uncle $crooge |
739, 741, 747, 748, CA3054, L272, L272M, LM224N, LM2904N, LM308N, LM3900N, LM392N, LM833N, MC4558CN and RC4559N ... now, with what I know about OP's (and that's not much) any of these should be able to "drive" the mosfet to generate V I need. but, I have all these lying around (more then 50 741's
http://www.it4um.com |
Most Mosfets don't work unless their gate gets +10V.
Most of your old opamps don't work when their supply is less than about 12V except the LM224 and LM2904 are fine. But with a 5V supply, their output high voltage is only +3.8V which is much too low for most Mosfets. Post your schematic showing a load current for the Mosfet for us to make suggestions.
Uncle $crooge |
argh .. ignore this .. this is just a part of the schematic .. and I do not like it anyway so i'll redo it myself from scratch
The circuit doesn't have a load and has no load current.
The Mosfet shorts 14V to 5V through its body diode. The non-inverting input of the opamp is connected to +7V which might destroy it. The Mosfet is tiny.
Uncle $crooge |
| Questions on Thermistor Circuit | bismark99 | General Electronics Chat | 14 | 1st April 2008 12:04 AM |
| 40w Amp with the NTE equivelant of the the TDA2030 | darwindeathcat | Electronic Projects Design/Ideas/Reviews | 12 | 10th February 2008 02:58 AM |
| Clamp output of op amp | dazza000 | Electronic Projects Design/Ideas/Reviews | 21 | 9th November 2007 08:31 AM |
| 741 - Comparator problems | Nutmegzzzz | Electronic Projects Design/Ideas/Reviews | 3 | 30th September 2007 07:42 AM |
| PA Amp; noise reduction help | CrazyOldGuy | Electronic Projects Design/Ideas/Reviews | 3 | 18th September 2007 04:46 PM |
