Old 9th May 2008, 03:10 PM   #1
Default TL084 quad op-amp help
I need to know at what input will the opamp trigger while giving 5v to the inverting end?
Im trying to use it as a filter and the FSK input is around 400mV but I am not getting any output from the opamp....so what is the input level required to get an output??
This is the circuit diagram ...it is the receiver part of the 125KHz RFID system design.
coolrfid is offline
Old 9th May 2008, 03:25 PM   #2
where do pins 4 and 11 go?
spuffock is offline
Old 9th May 2008, 05:15 PM   #3
Pins 4 & 11 are the voltage supplies to the opamp. ie +/-12v resp
coolrfid is offline
Old 9th May 2008, 09:05 PM   #4
Aren't you pushing the capabilities of the TL084 a little bit too far?
if I know the answer.
Hero999 is offline
Old 9th May 2008, 10:57 PM   #5
This 125kHz sometime goes through AM peak detection before reaching the op-amps. Possibly, coolrfid's creating a bandpass filter for the 12kHz and 15kHz FSK frequencies.
5V or even 400mV will be enough if your ± supply voltage is in the recommended ±5V to ±15V range
Since you're using a quad op-amp , I'll just wager you're using the TL084 to make Sallen Key filters and inverting amps. A lot of Sallen Key filters I find have unity gain. So if you're putting 400mV in, you should be getting almost 400mV out...unless it's outside your passband.
...That's just based on my guesses. First thing, post a diagram so we can see your amps/filters. Then tell us what frequency this 400mV is.
Also keep in mind the TL084 can't produce an output if the load impedance is under 100Ω.
The most-hated young engineer in America.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 10th May 2008, 07:08 AM   #6
The 400mV signal is the FSK modulated signal of the RFID tag around containing the frequencies 12KHz & 15KHz. Ive posted the circuit diagram ontop in d first post....Does the diode 1N4936 make a difference to the voltage level of the signal...can i use diode 1N4148 instead...
What u r saying is right.. im using the TL084 to make Sallen Key filters
coolrfid is offline
Old 10th May 2008, 07:45 AM   #7
The 1N4148 would probably give you a longer reception range because it has a low forward voltage (Vf). A germanium diode might be even better than 1N4148. They are the kind used in battery-less crystal radios, and take very little energy from your signal.
Probably I can look at this filter again tomorrow and make a test recommendation. For now, you should be able to see a 12kHz to 15kHz square wave on the final output if everything is okay (and possibly some 3rd frequency if there is no input at all). I'd start by inputting more 12kHz and 15kHz to see if there is a one or more Sallen Keys dropping the signal.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 10th May 2008, 06:17 PM   #8
Just for the record - 1N4936 has lower forward voltage than 1N4148, due to the larger junction. Look at the datasheets.
Ron
Roff is offline
Old 10th May 2008, 06:29 PM   #9
hi Ron,
The BAT43 and the old OA47 [Ge] are low Vfwd.
ericgibbs is offline
Old 10th May 2008, 06:41 PM   #10
Originally Posted by ericgibbs
hi Ron,
Hi Eric,
I wasn't making a recommendation. As I said, it was just for the record. I hate letting erroneous info go uncorrected.
Ron
Roff is offline
Old 10th May 2008, 06:46 PM   #11
Hi Eric,
Hi Ron,
I agree, I just thought I would add two more low fwd diodes to the mix.
What are you doing 'nerding' on a Saturday night, you should be out with the guys..
Old 10th May 2008, 07:48 PM   #12
Hi Ron,
I'm on vacation in Fergus Falls, Minnesota, where it's 1:45PM, raining, and about 4 degrees C outside. If it was warm and dry, I would be outside fishing or hunting coins with my Minelab Explorer SE.
Nerding is my fallback entertainment.
Actually, I guess you could say I'm always on vacation, since I'm retired.
Ron
Roff is offline
Old 10th May 2008, 10:10 PM   #13
Either way, I'd look into a Germanium device in the near future. It will work with a 1N4148 or 1N4936, but you might have better luck with Germanium.
Maybe start by probing filters A, D, B, C at their outputs and tell us if the 12kHz and 15kHz signals are getting through. Only filter C seems to be running at unity gain, so all the others should actually be making the 12kHz and 15kHz larger. Do you have an oscilloscope available?
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
opamp, quad, tl084
amp project andynerd General Electronics Chat 29 12th April 2008 04:24 PM
Amp wanted spuffock General Electronics Chat 4 12th November 2007 01:25 PM
Clamp output of op amp dazza000 Electronic Projects Design/Ideas/Reviews 21 9th November 2007 09:32 AM
PA Amp; noise reduction help CrazyOldGuy Electronic Projects Design/Ideas/Reviews 3 18th September 2007 05:46 PM
What amp rating do I need? jtbsc General Electronics Chat 4 8th September 2007 02:22 PM
