| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
| | #1 (permalink) |
| New Member Join Date: May 2008
| I need to know at what input will the opamp trigger while giving 5v to the inverting end? Im trying to use it as a filter and the FSK input is around 400mV but I am not getting any output from the opamp....so what is the input level required to get an output?? This is the circuit diagram ...it is the receiver part of the 125KHz RFID system design. |
| | #5 (permalink) |
| Experienced Member | This 125kHz sometime goes through AM peak detection before reaching the op-amps. Possibly, coolrfid's creating a bandpass filter for the 12kHz and 15kHz FSK frequencies. 5V or even 400mV will be enough if your ± supply voltage is in the recommended ±5V to ±15V range Since you're using a quad op-amp , I'll just wager you're using the TL084 to make Sallen Key filters and inverting amps. A lot of Sallen Key filters I find have unity gain. So if you're putting 400mV in, you should be getting almost 400mV out...unless it's outside your passband. ...That's just based on my guesses. First thing, post a diagram so we can see your amps/filters. Then tell us what frequency this 400mV is. Also keep in mind the TL084 can't produce an output if the load impedance is under 100Ω.
__________________ The most-hated young engineer in America. * AVR Projects * Robot War [for TI graphing calcs] * Robot War TI footage |
| | #6 (permalink) | |
What u r saying is right.. im using the TL084 to make Sallen Key filters | |
| | #7 (permalink) |
| Experienced Member | The 1N4148 would probably give you a longer reception range because it has a low forward voltage (Vf). A germanium diode might be even better than 1N4148. They are the kind used in battery-less crystal radios, and take very little energy from your signal. Probably I can look at this filter again tomorrow and make a test recommendation. For now, you should be able to see a 12kHz to 15kHz square wave on the final output if everything is okay (and possibly some 3rd frequency if there is no input at all). I'd start by inputting more 12kHz and 15kHz to see if there is a one or more Sallen Keys dropping the signal.
| | #8 (permalink) | |
| Experienced Member Join Date: May 2003 Location: Hew Hess of Hay
__________________ Ron | |
| | #9 (permalink) | |
| Experienced Member Join Date: Jan 2007 Location: U.K.
The BAT43 and the old OA47 [Ge] are low Vfwd.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ | |
| | #10 (permalink) | |
I wasn't making a recommendation. As I said, it was just for the record. I hate letting erroneous info go uncorrected.
| | #11 (permalink) | |
I agree, I just thought I would add two more low fwd diodes to the mix. What are you doing 'nerding' on a Saturday night, you should be out with the guys..
| | #12 (permalink) | |
Nerding is my fallback entertainment. Actually, I guess you could say I'm always on vacation, since I'm retired.
| | #13 (permalink) |
| Experienced Member | Either way, I'd look into a Germanium device in the near future. It will work with a 1N4148 or 1N4936, but you might have better luck with Germanium. Maybe start by probing filters A, D, B, C at their outputs and tell us if the 12kHz and 15kHz signals are getting through. Only filter C seems to be running at unity gain, so all the others should actually be making the 12kHz and 15kHz larger. Do you have an oscilloscope available?
| amp project | andynerd | General Electronics Chat | 29 | 12th April 2008 03:24 PM |
| Amp wanted | spuffock | General Electronics Chat | 4 | 12th November 2007 12:25 PM |
| Clamp output of op amp | dazza000 | Electronic Projects Design/Ideas/Reviews | 21 | 9th November 2007 08:32 AM |
| PA Amp; noise reduction help | CrazyOldGuy | Electronic Projects Design/Ideas/Reviews | 3 | 18th September 2007 04:46 PM |
| What amp rating do I need? | jtbsc | General Electronics Chat | 4 | 8th September 2007 01:22 PM |
