| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
i have searched for a PCB relay good for 30A at 28vdc, but i found a lot of relay good for 20A@28vdc (the g8p series from omron for example) or relay good for 40-50A at 14Vdc (automotive relay). Does it exist or i must use an external relay?
Experienced Member
You're going to have trouble making pcb traces for 30A.
That said, the Potter&Brumfield T9AS series includes some rated for 30A at 240VAC. I don't know the DC rating. |
well i dont have the choice i use full brick dc converter that are solderd to a pcb board and output 30Amp, i make the trace 200mil on each side of the pcb with 2 oz copper
the t9as are only rated 20A at 28vdc |
Experienced Member
The Digikey webpage lists a number of T9A's that are good for 30A at 240VAC. Are these only rated for 20A at DC? That would be unusual.
Experienced Member
Lefty
Measurement changes behavior |
Experienced Member
Experienced Member
Lefty
Experienced Member
What are you interfacing that requires 30A at 12VDC? Will two relays paralleled together fit your application?
Experienced Member
Paralleling two relay might not help because one will open before the other so the slower relay will bear the brunt of the arc.
Does it really need to be PCB mounted? You can get 28V 30A relays pretty cheaply. What about using a power MOSFET or do you really need the isolation? |
| High power LED 'stars' | speakerguy79 | General Electronics Chat | 1 | 20th March 2008 01:31 AM |
| high power low cost electronic switches | jumbodaddy | General Electronics Chat | 10 | 10th March 2008 10:29 AM |
| High power regulator | Electronics4you | General Electronics Chat | 10 | 28th January 2007 03:17 PM |
| High current flip-flop using a DPDT relay? | Sawblade | General Electronics Chat | 7 | 23rd June 2004 04:46 AM |
