+ Reply to Thread
Results 1 to 13 of 13
Thread: Need 0.48 ohm resistor
  1. #1
    ronhollenbeck Newbie
    Join Date
    Apr 2008
    Location
    Pasco, WA
    Posts
    1
    Default Need 0.48 ohm resistor
    I need a 0.48 ohm resistor for a Micronta multi-meter. Mouser has 0.47 and 0.5 ohm but no 0.48. Does anyone know of a source?
    Thanks,
    Ron
  2. #2
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,810
    Blog Entries
    13
    Quote Originally Posted by ronhollenbeck
    Thanks,
    Ron
    hi Ron,
    Do they have any 0.01R's, these are a standard value.
    If you have the space use a 0.47R and 0.01R in series, it sounds like a current shunt so consider the wattage.
  3. #3
    picasm Good picasm Good
    Join Date
    Sep 2006
    Location
    UK
    Posts
    358
    You could use a 0.51R and a 8.2R in parallel.
    I found those values using this resistor calculator:
    http://focus.ti.com/docs/toolsw/fold...elrescalc.html
  4. #4
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,775
    First off, why do you want a 0.48 ohm?, it's a really strange value - next, how accurate does it have to be? - both 0.47 and 0.5 are within 5%, which is probably as good a tolerance as you're going to get.
  5. #5
    Jim C. Newbie
    Join Date
    Sep 2008
    Posts
    2
    He wants the 0.48Ω resistor for the same reason I do. I accidentally overloaded the 500 mA ammeter portion of my Micronta VOM this evening. This shunt resistor turned to crispy charcoal bits in about 3 seconds.
    The closest I could find was here:
    www . surplussales . com / Resistors / WireWound / WW0015-1 . html
    They have a 0.47Ω 1% 0.5W
    and a 0.487Ω 1% 20W (pretty darn close -- but with that power rating will be physically too big).
    Our power is only .12 W so 0.5 W should be enough.
    Jim C.
    PS - board posting restrictions prevent me from posting proper URL. You guys will have to cut/paste and knock out all the spaces.
  6. #6
    on1aag Good on1aag Good on1aag Good
    Join Date
    Aug 2006
    Posts
    512
    Just a thought:
    2,4 / 5 = 0,48
    on1aag.
  7. #7
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,042
    You will not find a 0.48Ω resistor because it isn't a standard value, use 0.47Ω which is within 2% of the value.
    The nearest standard value is 0.481Ω which is a 0.5% tollerance resistor and I doubt you can get such resistors as low as that.
    http://en.wikipedia.org/wiki/Preferr..._and_resistors
    if I know the answer.
  8. #8
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,810
    Blog Entries
    13
    Quote Originally Posted by Hero999 View Post
    You will not find a 0.47Ω resistor because it isn't a standard value, use 0.47Ω which is within 2% of the value.
    Are you sure.?
    http://www.rhopointcomponents.com/pr...L+7520W+Series
  9. #9
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,810
    Blog Entries
    13
    Quote Originally Posted by ronhollenbeck View Post
    Thanks,
    Ron
    Any of these suitable.?
    http://www.rhopointcomponents.com/pr...gory=RESISTORS
  10. #10
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,042
    Quote Originally Posted by ericgibbs View Post
    I meant 0.48Ω, it was a typo as you probably know. I've edited my post.
    I was wrong about the tolerance though, it looks like you can get low value resistors this good, still no 0.48Ω though.
  11. #11
    Willbe Good Willbe Good Willbe Good
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    #30 AWG is 10'/Ω but it has a high tempco for this app.. It also doubles as a fuse.
  12. #12
    Valence_4 Newbie
    Join Date
    Oct 2008
    Location
    Montreal, Qc. Canada
    Posts
    32
    I'd suggest you to put in a 0.51 ohm (or two one ohm resistors in parallel) resistor in your VOM and then connect your VOM in series with a known good ammeter to check it's calibration. With a 0.51 ohmmer, you WILL get a too sensitive ammeter with your VOM. You'll have to add another resistor in parallel (PICasm suggests 8.2 ohms, try 8.2, 9.1 and 7.5 ohms) to fine-tune your VOM.
  13. #13
    Jim C. Newbie
    Join Date
    Sep 2008
    Posts
    2
    Thanks for the suggestion. I'll do that.
+ Reply to Thread
  1. Looking for a 300W .7 ohm resistor?
    By things in forum General Electronics Chat
    Latest: 20th March 2008, 03:29 PM
  2. Datasheet 330K 1/4W Resistor and 100R 1/4W resistor
    By kid in forum Datasheet/Parts Requests
    Latest: 17th February 2006, 02:55 PM
  3. 0R resistor and powerv rating
    By Scarr in forum General Electronics Chat
    Latest: 15th December 2005, 10:06 PM
  4. staged audio amplifier
    By mstechca in forum General Electronics Chat
    Latest: 2nd May 2005, 05:36 PM
  5. Resistor with single color band (a little long)
    By PANewbie in forum General Electronics Chat
    Latest: 14th January 2004, 09:36 PM
Tags for this Thread
