Old 12th April 2008, 08:18 PM   (permalink)
Default partial rotation trim pots, or such?
I'm looking for a way of measuring just a few degrees of rotation, and as always, on the cheap. Does anyone know of any products that are about as accurate as your average trim pot, but are specialized for only about 45 to 90 degrees of rotation? Thanks!
Hank Fletcher is offline
Old 13th April 2008, 01:01 PM   (permalink)
Perhaps you could find a cheap (Goodwill?) analog joystick and take out the pots. These usually are small rotation-angle pots. That said, I don't think you will find then any more "accurate" than just using the first 45 to 90 degrees of a ordinary pot.
What are you trying to accomplish?
Ken
KMoffett is offline
Old 13th April 2008, 01:53 PM   (permalink)
Simple, use a normal pot and gear it up.
Screen name: Aloone_Jonez
Hero999 is offline
Old 14th April 2008, 05:23 AM   (permalink)
Hero's idea is a good one. Just make sure you use a good quality POT if the there is going to be a lot of movement as the POT will wear out quickly especially if the movement is in one spot on the POT.
A better solution is a geared up shaft encoder out of an old mouse and will last much longer.
kchriste is offline
High quality CARBON pots for audio xmat Datasheet/Parts Requests 11 19th March 2008 08:43 PM
Boat trim indicator Techno Electronic Projects Design/Ideas/Reviews 13 4th August 2006 03:38 PM
changing ac electric motor rotation mountnman Electronic Projects Design/Ideas/Reviews 5 20th August 2004 02:42 AM
Interfacing Pots with a PC Brian Electronic Projects Design/Ideas/Reviews 4 15th April 2004 07:06 PM
Identifying Trim Pots Resistor Values Gotrek General Electronics Chat 7 9th January 2004 12:44 PM
