Old 14th March 2008, 04:45 AM   (permalink)
Default Component identification
I am tracing the circuit of a computer power supply unit (PSU), it blew up and I'm trying to discover why.
It has 2 identical components that I can't identify.
The attached photo, shows the PSU label with one of the components laying on it.
As you can see, it has SUM1-PA printed on it. They are designated V1 & V2 on the PCB.
Their position in the circuit makes me assume that they are voltage spike suppressors.
I did an internet search for a data sheet but no result.
Does anyone know what it is?
Any advice will be appreciated.
Len
ljcox is offline
Old 14th March 2008, 07:24 AM   (permalink)
Looks like a capacitor or surge-supressor with a heatshrink tube covering it. Can you remove the heat shrink with a razor blade?
ParkingLotLust is offline
Old 14th March 2008, 11:59 AM   (permalink)
Yes, Len, They are MOVs gripped in a heatshrinkable sleeving, as rightly pointed out by ParkingLotLust. This sleeve helps protect damages from blasted MOV in adverse conditions.
Regards,
Sarma.
mvs sarma is offline
Old 14th March 2008, 10:16 PM   (permalink)
Thanks for the replies.
I took the HST off and it is a TUR 07271.
There are also 3 blue devices that look like capacitors that I believe to be MOVs as they are very similar to MOVs that I've used in the past. They have 472M printed on them.
The TUR devices are labelled V1 & V2 whereas, the blue ones are CY1, CY2 & CY3.
Also, the TURs are smaller than the blue.
Len
ljcox is offline
Old 14th March 2008, 10:42 PM   (permalink)
They sound like 4700pF capacitors?.
Old 15th March 2008, 04:00 AM   (permalink)
Thanks Nigel.
That's what I thought, but I measured the capacitance of each (using my Atlas LCR meter) and they are 3.8 nF, 8.7 nF & 8.6 nF approx.
Whereas, I measured four 4.7 nF caps and they were in the 4.3 ~ 4.9 nF range.
I could not measure an actual MOV as I don't have one handy.
Also, their positions in the circuit are consistent with MOVs.
Len
ljcox is offline
Old 15th March 2008, 05:31 AM   (permalink)
MOVs -- perhaps not possible to check except it should show Mhm: s under normal situation.
there are spike simulating machines for checking the Device but we only see the physical conditions and satisfy. If there are cracks on thew body(exactly parallel to the circumference), better replace.
Regards,
Sarma.
component identification / equivalent spectrum General Electronics Chat 10 18th January 2008 06:49 PM
Component Identification ParkingLotLust Datasheet/Parts Requests 2 11th June 2007 09:17 PM
VHDL, Component, Structural design mus3na Electronic Projects Design/Ideas/Reviews 0 26th July 2004 09:20 PM
Component Identification. Elec. Nut Datasheet/Parts Requests 2 9th October 2003 05:18 PM
SMD Component Identification Shivleo General Electronics Chat 3 25th July 2003 03:27 PM
