Old 6th March 2008, 12:17 AM   (permalink)
Originally Posted by Hero999
The IRFU9020 is not a logic level MOSFET.
2 questions, 1)Any suggestions off the top of your head of a MOSFET I can use? 2) How would one go about finding the correct part w/o having to go through a million datasheets?
Thank you,
Dan
Ive got a head full of ideas and a wallet full of cobwebs
slopagafud is offline
Old 6th March 2008, 10:43 PM   (permalink)
I buy some of my stuff from ebay sellers. In this case I would simply search for logic mosfet. You'll notice that logic level mosfets are more expensive than the others, but they save the hassle of boosting the drive voltage.
You need to decide what current you need, and how many parts. Also surface mount, or not?
mneary is offline
Old 7th March 2008, 10:10 AM   (permalink)
You don't need a logic level MOSFET.
As this is a p-channel MOSFET so you need a MOSFET driver to convert the 0-5V pulses to 0-9V pulses.
If you just used a logic level p-channel MOSFET then it would never turn of, it will stay on when the PIC's output goes high.
Also, what power supply are you using?
If it's just a 9V battery, the voltage will quickly drop to 7.5V and it might not work.
Screen name: Aloone_Jonez
Hero999 is online now
Old 8th March 2008, 02:02 AM   (permalink)
I am using a regular old 9v batt
Thank you,
Dan
Old 8th March 2008, 10:45 AM   (permalink)
How much current are you planning to draw?
If it's over 100mA or so then I strongly advise using a larger battery like six AA cells.
Old 8th March 2008, 08:28 PM   (permalink)
Im only drawing about 10mA. Unfortunately I dont have the space for AA cells.I do plan on using Nimh Button cells though. I was going to use 7 connected in series giving me 10.1v @ full charge, Im using it in a different variation of this circuit, where Im using the PicAxe as a power switch for a 555.
Thank you,
Dan
Old 8th March 2008, 09:37 PM   (permalink)
If it's just 10mA then why not just use a PNP transistor?
The circuit for driving one from a PIC is shown below.
http://www.winpicprog.co.uk/pic_tutorial_extras.htm
Old 9th March 2008, 05:06 AM   (permalink)
Like I said I am just playing around w/ this. Seeing what I can, and cant do with different components, and configurations. Right now Im using an N-chan(2n7000) to pulse the (-) side of the circuit, but would rather pulse the (+) side. I was going to use an NPN, PNP similar to the schematic you posted, but Ive been playing with these MOSFETS lately and was curious if I could get the same result.
Thank you,
Dan
Old 10th March 2008, 10:15 AM   (permalink)
You could replace T2 with a MOSFET and remove R3 but R2 will form an RC circuit with the MOSFET's gate capacitance which will slow the off time too much for 30kHz operation.
If you want to drive your MOSFET at high speed, you need a MOSFET driver. You can use a special IC (recommended) or build your own from a few transistors (see attachment). In this case you only want to pulse the load at 10mA so it's not worth going to all the trouble, even more so considering the driver uses nearly as much current.
Old 10th March 2008, 11:55 PM   (permalink)
I was playing around last night using an N-chan (2N7000) and a P-chan(IRFU9020), set up similar to the first schematic you posted, and had very good results. Using my 10v batt pack, I got an output of 9.82v @ 30.2KHz w/ a 6.28mA draw from the batt. The batt only dropped <1v after a full run(10 min pulse 4x, 20 min pause between pulses, then complete shut down of the circuit) then Im using the same setup(N,P-chan) for the power hold on the PIC. Ill draw the schematic later.
Thank you,
Dan
Fast Line-Follower Motor Selection? What to Look For... richardv2 Robotics Chat 10 25th January 2008 03:02 AM
Fast reply / Quick Reply. lord loh. Feedback/Comments 6 24th April 2006 01:12 AM
Help needed fast - LM339 CommanderKeen General Electronics Chat 3 23rd April 2006 09:46 PM
Help - programming Motorola Intrac2000 modules - pc too fast Stressed_Eric Electronic Projects Design/Ideas/Reviews 3 12th March 2004 01:53 PM
NiMh Fast Charger for 24V 36V 48V packs, 9Ah design - help! nocman43202@yahoo.com Electronic Projects Design/Ideas/Reviews 0 27th July 2003 10:00 PM
