| Notices |
| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
| | (permalink (permalink)) |
| Does anyone know how this is connected? My adapeter has gone all coroded (dont ask me how) I would like to just cut the cable and atache a new db9 plug
__________________ Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? | |
| all the magic is in the db9 plug, so if you cut it off, you're done. the damn things are usually sealed in some sort of rubber too, making it very hard to service them. try your best to cut open the DB9 connector and then you can solder on a new usb cable.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| Well its the db9 plug thats shot. But ill give it a try. My has a plastic casing (solid of corse..) Ill also try to make a schematic to post here if others need to do similar things.... or if you want to make something that are meant to be RS232, to USB
| Well, if you can get it open, soldering on a new db9 shouldn't be a big deal. they usually just use a solder cup type which straddles the pcb, and solder it on both sides.
| I suggest, as anyway you need to rewire it, cut it 2" below and slightly open the cable and remove wires' insulation, perhaps you can buzz the wires and note down data. It would be easy to rewire exactly on a fresh DB9.
| Yes the new DB9 is easy and its the part that i need to replace. After opening the boks on the DB9 end i was a bit suprised to find that amount of electronics inside So the resolder is really easy i can see
| Well i dont know what that look like but here is a couple of shoots I just took to show you all: The first is th reason why I opend it and the other two are from inside the cable ENJOY
| Nice Job Kryten and thanks. A lot of components. Perhaps now you can replace the DB9 male connector alone carefully and pack it back, and seal it with some superglue. If you have access to an hot-air gun, your job is simple. I was anxious to know, what actually this cable does. what is at the other end? An USB? or RS232 with tx, Rx and common? Thanks again
__________________ Regards, Sarma. Last edited by mvs sarma; 7th February 2008 at 07:56 AM. | |
| Its a USB to RS232 cable (as my laptop dosent have any Serial ports)
Its double sided but uses only one chip FT232RL. PCB layout attached.
__________________ Regards, Sarma. Last edited by mvs sarma; 7th July 2008 at 12:14 PM. | ||
| USB Power hack with DC/DC Converter - am I crazy? | chconnor | Electronic Projects Design/Ideas/Reviews | 14 | 8th March 2008 09:12 PM |
| USB to RS232 driver | flemmard | Electronic Projects Design/Ideas/Reviews | 1 | 6th October 2007 07:03 PM |
| RS232 Converter | e.chain | Micro Controllers | 0 | 6th October 2007 06:19 PM |
| usb to RS232 serial port : | simrantogether | Electronic Projects Design/Ideas/Reviews | 3 | 12th September 2007 12:04 PM |
| RS232 buffer | TDY | General Electronics Chat | 3 | 18th March 2005 08:36 PM |
