Notices
Old 2nd February 2008, 07:55 PM   (permalink (permalink))
Default IRFP460N MOSFET gate driver
hi
i have IRFP46N MOSFET
and i need the gate driver for it
can anyone give me its model number
that driver which compatipale with 5V input
h.d is offline
Old 2nd February 2008, 08:05 PM   (permalink (permalink))
THere are a bunch. But the LM5111/LM5112 or TPS812 (and the others in the same datasheet) will do it. THese are low-side drivers only. For high-side you would need either a floating (isolated) DC-DC converter, or more economically an IR2010 or some other IC like it.
dknguyen is offline
Old 3rd February 2008, 09:37 AM   (permalink (permalink))
Have a look at the drivers offered by Intersil (www.intersil.com)
I try and use them as a company as much as I can as their service and support is excellent.
One of the few companies I've never had a bad word to say about.
picbits is offline
Old 3rd February 2008, 07:47 PM   (permalink (permalink))
the IRFP460 Vgs=+-20V
and the driver you added is 10V output
if the mosfet work in that Vgs i think the heating will be large,isn it?
h.d is offline
Old 3rd February 2008, 07:58 PM   (permalink (permalink))
Rds(on) is spec'ed at 10V. Vgs=+-20V (+-30V in the datasheet I looked at) is the absolute maximum limits, beyond which you may break down the gate.
What are you driving with the RFP460? Many applications just need a simple level translator, which can be done with an NPN and a couple of resistors.
Ron
Roff is online now
Old 3rd February 2008, 08:09 PM   (permalink (permalink))
A single NPN is fine at low frequencies but a push pull NPN+PNP driver is required at higher frequencies.
Screen name: Aloone_Jonez
Hero999 is offline
Old 3rd February 2008, 08:11 PM   (permalink (permalink))
That was the reason I asked the question. I should have also asked what his switching frequency and duty cycle is.
Ron
Roff is online now
Old 3rd February 2008, 08:12 PM   (permalink (permalink))
the application is to drive dc-motor by PWM,the MOSFET is connected in low side,the PWM signal come from PIC output which is 5V so i need the gate driver to to drive the MOSFET gate from the PIC output.
the current will go through the MOSFET is typicaly 7-8A
h.d is offline
Old 3rd February 2008, 08:19 PM   (permalink (permalink))
i dont know how to determine the frequency?and which frequency you mean?
sorr for the lake question.
about the duety cycle for PWM
i have motor with 220 DC and ineed to varey the speed from 0 to full speed (2500rpm)
so the d.c will varey from 0 to 100%
h.d is offline
Old 3rd February 2008, 08:23 PM   (permalink (permalink))
What is your PWM frequency?
And can't you find a MOSFET with lower Rds(on)? 0.25 ohms will dissipate 16 watts at 8 amps.
Ron
Roff is online now
Old 3rd February 2008, 08:38 PM   (permalink (permalink))
realy i dont know how to determine the PWM frequency..
if you can tell me how????
h.d is offline
Old 3rd February 2008, 08:53 PM   (permalink (permalink))
i dont know if that you ask about
but in pwm i will varey the ton with constant T
so i think the frequency is constant
but i dont know whats the difference if it high or low frequency
h.d is offline
Old 3rd February 2008, 09:09 PM   (permalink (permalink))
WIth PWM the frequency should stay the same, only the duty cycle should change.
The frequency equals the 1 divided by the sum of the on and off times.
Hero999 is offline
Old 4th February 2008, 05:34 PM   (permalink (permalink))
the microcontroller frequency is 4MHZ
h.d is offline
Old 4th February 2008, 05:41 PM   (permalink (permalink))
Ok - so have a look at your datasheet and your code and work out what your PWM frequency is.
picbits is offline
Mosfet Driver ! Inferno Electronic Projects Design/Ideas/Reviews 18 17th June 2007 08:35 PM
H bridge MOSFET gate fabbie Electronic Projects Design/Ideas/Reviews 34 15th December 2004 07:38 AM
UNiversal MOSFET Gate drivers alanlts Electronic Projects Design/Ideas/Reviews 2 9th June 2004 10:21 AM
Here is a list of semiconductor prefixes. TPS Datasheet/Parts Requests 0 21st December 2003 07:24 PM
Identify Semiconductors by prefixes mixos Datasheet/Parts Requests 0 10th December 2003 06:55 PM
