Old 29th January 2008, 07:08 AM   (permalink)
Default Need Help in DC/DC Inverter
Hi guys,
Any suggestion on the component (model and brand) for 12V to -12V DC/DC Inverter IC?
Harros is offline   Reply With Quote
Old 31st January 2008, 02:48 AM   (permalink)
How much current? Regulated?
mneary is offline   Reply With Quote
Old 31st January 2008, 06:38 AM   (permalink)
maybe this. dunno about current, but i'm sure you can use 12VDC with a 555.
Every little bit counts! It works with money, and it works with electronics!
bunghole is offline   Reply With Quote
Old 31st January 2008, 01:15 PM   (permalink)
Harros,
You did not give us much information!
Look at the LM2611. It will do +12 to –12 conversion with few parts. Only 200 to 300mA. Small!
ronsimpson is offline   Reply With Quote
Old 31st January 2008, 03:29 PM   (permalink)
This is the simulation result of the circuit that i want to implement the battery power management. I intend to drive this circuit using 9V battery... Is it possible to do so? If it is possible, any suggestion on the regulator/ converter that I should use to make this circuit working?
Old 2nd February 2008, 04:48 PM   (permalink)
Look at the datasheet.
Will the LM2611 work at 6V?
You could bais the 0V nodes at half the battery voltage but some of the resistors are a little low for that. Another option would be to use another op-amp like the 741 configured as unity gain buffer with the input biased to half the battery voltage and 100nF capacitors connected between the output and the + and - rails.
Screen name: Aloone_Jonez
Hero999 is online now   Reply With Quote
USB Power hack with DC/DC Converter - am I crazy? chconnor Electronic Projects Design/Ideas/Reviews 14 8th March 2008 09:12 PM
Carson Inverter Wiring Question goldenoldie General Electronics Chat 15 19th November 2006 07:12 PM
using a 320W flash with a 150W inverter denoise General Electronics Chat 5 19th February 2006 03:44 PM
inverter or inverter? glmclell General Electronics Chat 1 11th August 2004 12:16 AM
Using a UPS as a inverter IRQ57 Electronic Projects Design/Ideas/Reviews 1 25th November 2003 02:49 PM
