| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
| Hey, Does anybody know where I could find a low current as small as possible 4MHz quartz suitable for use to drive a PIC? Currently using FQ1045A-4 from FOX electronic but its size (10*4mm) will have to be minimised for our implant, ideally something like 5*4mm. Unfortunately the internal oscillator is not accurate enough with temperature for our application. I have found the CX3225SB from Kyocera Electronics which looks ideal but the company are not releasing the part for purchase or sample. | |
| What about SMD? Would this work? http://www.kingstate.com.tw/p10/p5-07.htm | |
| There is a guy selling them on Ebay... | |
| I don't know about PICs but AVRs internal oscillators are trimmable and some have onboard temperature sensors (attached directly to the die) which allows the osc to be trimmed over it's temperature range. What PIC are you using and exactly what kind of clock accuracy do you need?
| An implant with temperature stability issues? | |
| Cant go into too much detail... patent pending. I think 200-300ppm accuracy would be ok. We are using the PIC18F2520. It looks like internal osc is +/- 2%?? I checked out the AVR thats a nice little function.. unfortunately 25,000 lines of PIC assembly would rule out changing! I'm looking at using the internal oscillator with internal online tuning (OSCTUNE)... is it possible to tune without an external reference, since at the end of the day Timers, USART etc are all clocked off the same source. Last edited by col_implant; 15th November 2007 at 11:56 AM. | |
| | (permalink) | |||
| Or read why small inventers should probably avoid them. Don Lancasters case against patents. http://www.tinaja.com/glib/casagpat.pdf | |
| | (permalink) | ||
See this pdf from ECS the Crytal makers http://www.ecsxtal.com/store/pdf/ecs-3x10.pdf
From data sheet Accuracy is +/-2%, or +/-5% above 25C, we will be at body temp 37.5C | ||
If your device has a similar feature, you can turn on CLK out, and with a frequency meter, then change the 'OSCAL' value to best match 4MHz in your environmental specifications. Noting down that value, you would then have one MCU running at close to 4MHz, which would have to be loaded at startup. | ||
| Also, I believe the +-5% accuracy is an error-range for the device in general. One particular chip might be spot on 4MHz, whilst the maximum error above 25C is 3.8MHz-4.2MHz. | |
| Transmitting small voltages | aibelectronics | Electronic Projects Design/Ideas/Reviews | 8 | 24th May 2006 06:11 PM |
| some "melt damage" with my small motor invention. | windshield | Electronic Projects Design/Ideas/Reviews | 6 | 15th September 2005 02:20 AM |
| Simple Questions for small Motors | demestav | General Electronics Chat | 4 | 28th February 2005 12:40 AM |
| Help: Need idea for a small conveyor belt project? | Tyggr181 | Electronic Projects Design/Ideas/Reviews | 8 | 7th July 2004 12:15 PM |
| Small display | rik | Datasheet/Parts Requests | 3 | 23rd September 2003 10:56 PM |
