Old 9th November 2007, 07:55 PM   (permalink)
Obvious method would be to use a PIC to do it, and either run four traces as planned, or even one as a simple serial interface. You've not mentioned what the rest of the project is?, but it's probably also simpler to replace the rest of it with the same simple PIC? - or a couple of them?.
Old 10th November 2007, 05:24 AM   (permalink)
I really don't have any experience in PIC work. I've been thinking about diving into that world, but really don't know what type of programmer chips etc would be a good starter kit.
I pretty much know when I get into that, I'd want to use flash based PICs for learning on so I can play around without spending several dollars per chip. If you happen to know of an easy programmer to learn on, please feel free to recommend one. I'd like to try to stay under $50 for a whole kit (1 flash chip, programming hardware, and software) if possible.
danuke is offline   Reply With Quote
Old 10th November 2007, 08:16 AM   (permalink)
Check out the InchWorm, an ICD2 clone - cheap and VERY capable.
Old 12th November 2007, 09:12 PM   (permalink)
does the inchworm+ come with the components and circuit board or just the circuit board?
Old 12th November 2007, 09:34 PM   (permalink)
If you're using USB then I'd recommend a Junebug, the kits come with all the parts.
Since dipmicro does not carry the Junebug I'll see what I can arrange with Creatron Inc (they have stock both kit and assembled)
Bill
Smart Kits build Smart People
Old 13th November 2007, 06:03 PM   (permalink)
Originally Posted by danuke
I'm using it to encode 12 pushbuttons into a 4 bit code. It's not for a keypad per say but something similar. It's just going to take the 12 pushbuttons and make it into a 4 bit binary value so that it can be used with less traces to be run, etc on a pcb.
A simple solution, which you might consider, would be to use an EPROM to perform the encoding. A 4096 x 8bit device (such as a 2732A) has 12 address lines - one for each pushbutton, with only four of its data lines required for your binary encoded output.
The binary output code would have to be programmed into just 12 memory locations - those accessed when a single address line is asserted, e.g.
address 0000 0000 0001 would hold 0000 0001
address 0000 0000 0010 would hold 0000 0010
address 0000 0000 0100 would hold 0000 0011
address 0000 0000 1000 would hold 0000 0100
address 0000 0001 0000 would hold 0000 0101
and so on, up to
address 1000 0000 0000 would hold 0000 1100
All other locations could be filled with zeros, so that if two (or more) buttons were pressed simultaneously, the output would be zero.
2732 type EPROM's are now obsolete (superseded by much higher capacity devices), though they can still be regularly found on a certain auction web site. Alternatively, a higher capacity device could be used, with the unwanted extra address lines tied to ground.
hysteresis is offline   Reply With Quote
Old 17th November 2007, 05:06 PM   (permalink)
I like the EPROM chip approach and got a few from my neighbor who had some spares from where he used to work. Will definitely try my hand at EPROM programming to see what it has to offer.
Is there a good dumbed down tutorial site that can help me learn how to use the software to program the PIC using the inchworm? I find that I usually learn better by seeing the code that does a function and see comments with what certain lines do with it. Sorry if I should have started a new thread for the preceding questions about PICs.
Thanks again for all the help.
Need advice about this AC Line Current Detector Avocado Electronic Projects Design/Ideas/Reviews 6 21st March 2008 05:36 PM
DS1302 with PIC16f877 program RasCreationKing Micro Controllers 28 3rd May 2007 12:03 PM
Advice needed - regarding use of optical encoder. Denniswho Electronic Projects Design/Ideas/Reviews 2 10th April 2006 06:19 AM
QBasic Serial Port Control DigiTan Micro Controllers 3 5th January 2006 11:31 PM
LCD 4 Line 40 Character Interfacing rwamser Electronic Projects Design/Ideas/Reviews 5 28th November 2003 12:44 AM
