Old 2nd September 2007, 04:27 PM   (permalink)
Question Thermal fuse ?
I have a 1993 Mercury Capri with only 10,000 miles on it. The excerpt below is regarding the airbag controller.
NOTE: The diagnostic monitor contains an internal thermal fuse that is not serviceable. The thermal fuse is controlled by the diagnostic monitor. The diagnostic monitor will blow its thermal fuse whenever a short on the deployment circuits occurs. The thermal fuse does not blow because of excessive current flowing through it. DO NOT attempt to jumper across the thermal fuse with a circuit breaker or any other type of fuse.
CAUTION: Do not install a new diagnostic monitor until the short has been located and corrected.
From the Capri forum I found out that just humidity can make the controller blow its fuse. (Design flaw) The short is gone and the diagnostic monitor is $200.00. The thermal fuse looks like a glass reed switch and is located inside a tiny box, next to the heater that blows it. Somewhere they said it is 10 amps but they melt it intentionally with heat.
Does anyone know where I can get a 10 amp, thermal fuse like this?
C:\WHUT ?
Beware the asterisk *
ClydeCrashKop is offline   Reply With Quote
Old 2nd September 2007, 05:31 PM   (permalink)
Doesn't sound like a real fuse, sounds like a thermally triggered switch. There has to be more than two wires going to it right?
straight answer, har har."
Old 2nd September 2007, 06:38 PM   (permalink)
No, just 2 axial leads. The burnt one has a metallic black area on the inside of the glass tube. There are no end caps like an automotive fuse. Like a 1/8 inch blown glass tube.
Actually, the little plastic box with the heater and thermal fuse might come as an assembly with 4 leads and look like a small PCB relay. I would be happy to get that.
C:\WHUT ?
Old 2nd September 2007, 06:59 PM   (permalink)
Have you tried Radio Shack? As the equivalent store in the UK, Maplin Electronics, stocks a range of them (in 9 temperature ratings from 93°C to 240°C):
http://www.maplin.co.uk/module.aspx?...y=2m9#overview
(NB If you click the 'Specification' tab, you will see that they are rated at 10 Amp).
hysteresis is offline   Reply With Quote
Old 2nd September 2007, 07:48 PM   (permalink)
Thanks Sceadwian,
I found them. Also known as TCO, thermal cut out.
I also found out something about Googling and will post it in Chit Chat.
C:\WHUT ?
Old 2nd September 2007, 09:40 PM   (permalink)
Thanks Hysteresis
That is even better
C:\WHUT ?
PCB thermal resistance Oznog General Electronics Chat 3 23rd July 2007 04:45 AM
Question about relating thermal fuse ratings omgwtfbyobbq General Electronics Chat 5 4th July 2007 09:53 PM
Thermal fuse/cutouts mahinda jayasinghe General Electronics Chat 1 6th April 2005 01:11 AM
Looking for a thermal fuse for my Dryer ftjn052 Datasheet/Parts Requests 1 24th August 2003 10:06 PM
Looking for a thermal fuse johanm General Electronics Chat 6 2nd June 2003 04:41 PM
