| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
| I've been using the 4066N analog switch in a number of projects lately. My projects involve switches that are common ground; they are High when not pressed, and low when pressed. The 4066N enables the analog switch when the control line is high, and disabled them when low; the opposite of what I need. The only other 'active low' analog switch I've found is the MAX4611. It works great, but is costly ($1.50 vs a 4066N's .50) and not as readily available. Speed, On resistance, etc, are not much of a concern, so economical options are better than high performance ones. Is there a 'standard' analog switch IC, available in DIP, that enables the switches on low? | |
| You can use the 4053 which contains 3 SPDT analog switches and just wire to the normally closed contact. Or you can use a spare switch from the 4066 and a resistor to invert the signal.
__________________ --- The days of the digital watch are numbered. --- | |
| The DGxxx series of analog switches from Vishay and others should fill the bill For example the DG411 has an SPST x 4, NC configuration which is just the ticket for you. http://www.vishay.com/docs/70050/dg411.pdf Edit: Just checked Digikey prices and they're out of range for you. I guess you're stuck with using an inverter. Last edited by Papabravo; 31st July 2007 at 12:11 PM. | |
| I do need to invert control lines if I keep with the 4066N, but I'll need to invert between 12 and 15 of them. Thanks, but I'll stick to the 74HC14's | |
| Please help me in writing code | abdosat2000 | Micro Controllers | 9 | 5th June 2007 02:41 PM |
| DS1302 with PIC16f877 program | RasCreationKing | Micro Controllers | 28 | 3rd May 2007 01:03 PM |
| Push-buttons and PICs | NJ Roadmap | Micro Controllers | 11 | 31st March 2007 03:30 AM |
| PIC Switch Management Techniques | Mike, K8LH | Micro Controllers | 2 | 28th September 2006 01:33 PM |
| electronic switch to enable a camera to fire a flashgun | tony ellis | Electronic Projects Design/Ideas/Reviews | 10 | 30th September 2004 11:19 AM |
