Old 1st March 2007, 09:31 PM   #1
Default Unknown Transformer
This is a long shot, but I'm trying to find out the make and model of a transformer I worked with briefly about 3 years ago, and can no longer find in my lab. I wrote down all the markings I could see on the package:
Part number? "MGO - W26350" or "MCO - W26350"
Only other markings were for the primary and secondary:
"1-2-3 3k CT PAT"
"4-5-6-7 3k SPLIT"
It was a small PCB-mount transformer used for isolation of 0 - 5V AC signals.
Like I said, it's a long shot for anyone to simply recognize that part number, but I'm hoping. Apparently Google hasn't heard of it either.
Hardwire is offline
Old 2nd March 2007, 11:00 PM   #2
What frequency?
How about a mains transformer with a twin 0-6V primary?
if I know the answer.
Hero999 is offline
Old 5th March 2007, 04:07 PM   #3
Originally Posted by Hero999
What frequency?
Can't really talk about the frequencies. I've found another transformer that works okay for the application but an older more "original" design used this unknown transformer that I can't find anymore. Was just hoping that someone recognized the part number, but it's a long shot at best.
Hardwire is offline
Old 5th March 2007, 09:48 PM   #4
Just out of curiosity what type of transformer did you use in the end?
Hero999 is offline
Old 6th March 2007, 01:47 PM   #5
Tamura TTC-203SL:
http://www.tamuracorp.com/clientuplo.../TTC-203SL.pdf
The datasheet says it's freq. response is only up to 3.5kHz. I'm pretty sure the older unknown transformer had a wider range, so I'm looking into other replacements.
Actually, I have a question. If you can see the datasheet I linked, what exactly does the spec mean for frequency response? "0.15, -0.35dB 300Hz to 3.5kHz"? Does this mean response has only dropped by 0.35dB @ 3.5kHz?
Hardwire is offline
Old 6th March 2007, 06:52 PM   #6
if you cant't talk , at least you can say the sorroudigs where it it is used and for what purpose? whether the primary is connected or expected to be connected to public mains as input / or/
is it connected to telecom or modem -- /or/
is it an smps power supply transformer--
if you can't speak for your requirements -- how can these doctors treat your case dear
Sarma
Regards,
Sarma.
mvs sarma is offline
Old 6th March 2007, 07:12 PM   #7
Sarma
I was just hoping that someone recognized the part number in my first post. I have chosen a replacement part that seems to work well.
But here are some more details about the application:
This transformer is being used to isolate incoming -2.5V to +2.5V sinusoidal signals from another system. There is basically a pre-amplifier that must be isolated from a signal processing circuit. If the output of the pre-amp is not transformer isolated from the input of the processing circuit, it doesn't work (signal processor doesn't read correct frequencies/levels, etc.). It is a little like AC coupling an input to throw away DC levels.
No connection to public mains or anything... primary is just passing sine waves to the secondary for isolation purposes.
Hardwire is offline
transformer, unknown
Transformer Problems? MsStateDawg Electronic Projects Design/Ideas/Reviews 15 2nd November 2007 11:17 PM
Problems selecting a PCB Transformer NewcastleSAR Datasheet/Parts Requests 31 4th January 2007 08:16 PM
Transformer + battery = School Thrills windozeuser General Electronics Chat 3 14th December 2005 10:28 PM
Differential transformer how to measure this signal sardineta Electronic Projects Design/Ideas/Reviews 18 7th October 2004 03:31 PM
Transformer Help Falks Electronic Projects Design/Ideas/Reviews 2 1st September 2003 06:37 PM
