| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
| Experienced Member | If you search my recent posts, youll see I have a buzzing WRT54G. The power brick is whats doing the buzzing. I discovered that if I removed the PWM chip, it stopped. I purchased a replacement and installed it, and now it still buzzes. This leads me to believe the other chip might have been bad. Since I have no freakin' clue whats wrong with it, Im left replacing chips until it works again. Anyways, I need an equivalent to a chip with the following markings. I google'd it and couldnt find any matches in terms of the markings. 9936 31B9MIt is an 8-pin SOIC chip, located right at the power input. I can try and get a close-up picture of the location of the chip if it will help. |
| Experienced Member | the wrt54g contains an onboard buck converter, I believe accepting up to 20v and down to 5v, the unit itself running on 3.3v. have you tried using other power bricks, to see if they have the same problem? my wrt54g (all three of them) came with heavy unregulated "12vdc" power supplies ... the heft implying a simple transformer + rectifier + cap configuration, leaving the regulation to the chip onboard the wrt in the field I run my wrt off a parallel bank of 6v gel-cells which fit nicely in a small camera bag, but have also run it straight off "12 volt" power from my truck and a 12v deep-cycle battery, it's a pretty flexible chip all that being said, if there were something wrong with the chip, it would either not work at all, get terribly hot, smoke something else in the router or all of the above. has any of these symptoms occurred?
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
| Experienced Member | I replaced the synchronous buck pwm controller chip. That was my first guess since it would handle the incoming power, but that didnt fix it. I bought it for $20 off eBay, as being broken, as something to play around with. Its running off the power brick that came with it. I have a v5 running dd-wrt but theyre a different voltage brick, so I dont want to hurt it. I believe the one I have is a v1 or a v2 (with the mini-pci card on the wrt54g board). Anything else I can try before I start replacing more chips? |
| Experienced Member | Hi, whether the buzz (if it is audible) is not due to transformer packing being loose and the coil former sitting loose on the Ferrite core and things like this--
__________________ Regards, Sarma. |
| Experienced Member | So what should I do to fix it? I dont quite understand what you're saying. |
| Experienced Member | Also a bad output or input cap can cause instability that can make audible buzzing. If the supply has a prob causing terrible ripple, that can cause a similar instability prob.
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
| Experienced Member | So try replacing the big electrolytics by the input jack aswell? Ill try another power brick too if I can get my hands on one of the same rating Last edited by ParkingLotLust; 4th January 2007 at 06:50 AM. |
| Super Moderator | To be honest, I would have thought the least likely cause is going to be a faulty IC - as suggested FAR more likely is the transformer mechanically noisey, or a faulty capacitor. |
| Experienced Member | Will it do any damage to remove a capacitor and test? |
| Super Moderator | Quote:
| Experienced Member | Hmm which caps are we talking about, that could be bad? the ones in the power brick, or the ones on the board of the router? |
| Experienced Member | whichever electrolytics there are, replace 'em both, they're cheap! I see two on my wrt54g rev 1
| Experienced Member | My board looks more like this. Which caps should I be replacing? The big pair, or the small pair? http://seattlewireless.net/~mattw/ph...e/IMG_3425.JPG |
| Experienced Member | oh, that's not your board ... but if yours look like that, with no visual signs of distress, I'd be highly suspect of anything being wrong with the caps. if you still want to replace any, replace all four, two big ones and two little ones.
| Experienced Member | Thats exactly what my board looks like. No visual signs of wear or anything. Thats why I suspected the chip, because when I removed it the buzzing stopped, but it obviously still doesnt work. |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 09:39 AM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 12:44 PM |
| Power Supply for a project to be powered within an Auto? | hexibot43 | General Electronics Chat | 16 | 8th September 2005 02:35 PM |
| Power Supply Failure | Joel Rainville | General Electronics Chat | 8 | 24th August 2005 01:41 PM |
| Low current power supply from stored current. | McGuinn | Electronic Projects Design/Ideas/Reviews | 12 | 20th January 2004 06:14 AM |
