| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
Hi Folks..
I'm finalising all the parts for the Darkroom timer based on two circuits before I decide on which one to build but have run into a difficulty selecting the Transformer I need. As I have two circuits to choose from, the transformer the two circuits quote are: Mains Transformer 6V 1.5VA (PCB Mounted) and 220VAC 15VAC 1VA PCB Transformer I've gone to RS Components to source the Transformers @ http://rswww.com/cgi-bin/bv/rswww/se...0&cacheID=ukie and tried using their filtering system to narrow down the types available but I can't seem to match what they have against what I need. Could anyone assist in picking out the code for the transformers I require? Based on my searching For the 220VAC 15VAC 1VA PCB Transformer, the nearest I can seem to match is the following: http://rswww.com/cgi-bin/bv/rswww/se...0&cacheID=ukie and for the Mains Transformer 6V 1.5VA (PCB Mounted) I get http://rswww.com/cgi-bin/bv/rswww/se...0&cacheID=ukie I gather that the VAC is the AC voltage in and the AC voltage out but what is the VA quote and how does it match up with output current. Many thanks on this longwinded posting. Declan |
VA is Volt/Amps - essentially the wattage (power) of the transformer. 1VA and 1.5VA are VERY low power transformers.
Most transformers secondaries are rated for a specific voltage at a specific current, if the current draw goes higher than that the voltage drops as the inductive coupling isn't high enough to transfer more power. I'm going to hazzard a guess that if you try to draw power past the VA rateing of a transformer that core losses in the transformer are going to become very high and the voltage is going to drop significantly.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
I don't think there's any need to 'over analyse' it? - try and take too much power and the transformer will overheat and fry!.
Please post a link to the project and or a schematic so we will be able to tell you if the transformer is suitablity sized.
Really the biggest problem is finding a transformer that fits the PCB, they are usually all a little different.
But from RS Components there's a 6V 1.5VA under 347-3388, and a 15V 1.5VA under 347-3417 - they don't list a 15V 1VA (at least on the first page). |
Oops..
Sorry folks about the RS Components links. I didn't realise that they had an expiry level on them. I've attached the two schematic diagrams for kind souls to have a look at. This project is also in reference to another link about an S201S01 Traic although I think I have the triac sorted. BTW, RS components is my main supplier as I have an account with them hence the links I was using to RS Regards Declan |
Hi Nigel..
Sorry about the links to RS Components. What you have quoted below is what the links I had should have pointed you towards. Is the 347-3388 transformer suitable for this circuit? In relation to the 220VAC/15VAC 1A transformer, the nearest I could get was the 347-3417. If this okay? I've emailed the Author of the 220VAC/15VAC 1A transformer and awaiting a reply. Regards Declan Quote:
EDIT: I've just checked the diagrams you posted, the 6V one is 1.5VA, the 15V one is 1A (15VA), so if you wnat to build that circuit you need to look for a 15VA transformer. Bear in mind, most of the RS transformers have two windings, which you should connect in parallel. The 6V one lists a Conrad transformer, have you considered ordering that?. Last edited by Nigel Goodwin; 1st January 2007 at 07:59 PM. |
Sorry Nigel..
There appears to be a typo on the Parts list page of this project. I quoted what was on the Parts/component list. It states on this list 220VAC/15VAC 1VA PCB Transformer. Having now looked at the schematic, it states 220VAC/15VAC 1A Would that now suggest that the transformer 347-2824 from RS be the one I would be looking for? In relation to the 6V one you quoted (347-3388) okay for this circuit. The reason for not ordering from Conrad is that they have aminimum order of 50 Euro plus, it has an omber traffic light which I assume means that they don't have them in stock. Declan Quote:
That ones 36VA not 15VA - it would work fine, but will be more expensive and larger than needed.
Well the schematic is wrong, you need a 9V 1VA transformer.
6V is too low due to the dropout voltage of the LM7805 and 15VA is too big because this circuit only draws a very small current.
Hi Nigel..
Based on the info you now know, which transformers would you recommend in the RS range? Hero999.. What would be your recommendations from RS components As it is, I'm still waiting on responses from the Guys that designed the circuits. Regards Declan Quote:
(permalink) | ||
Hi Hero999
Many thanks for that. Can you recommend a good book or website location that would help me understand transformers and how to select the correct one. I'm still trying to tie in the values of the transformer in the circuit to understand the VAC (in/Out) versus the VA values and the output current it can supply. In simplistic terms and at the risk of getting a smacked, with reference to the 220VAC/15VAC 1A transformer, is this essentially a transfomer that steps down 220 Volts AC to 15 Volts AC and can supply an output current up to 1 amp? I can't seem to marry the 15VA and the output and 1A for this transformer to one at RS. The nearest I get to it is 347-2694 (16VA) but it only supplies 0.5A. The next one up is the 201-8738. Its supplies 0.73A but the VA has gone up to 22VA. In the 6V transformer circuit, is the reason for specifying the 8V (or 9V) transformer due to the 7805 regulator needing a minimum voltage of 7.5V for it to operate? Sorry if all the questions sound dumb. Declan Quote:
| transformer question | qsiguy | Electronic Projects Design/Ideas/Reviews | 14 | 7th April 2008 06:08 PM |
| Transformer Problems? | MsStateDawg | Electronic Projects Design/Ideas/Reviews | 15 | 2nd November 2007 10:17 PM |
| Circuit Design: Transformer (or Inverter?) | jrod5000 | Electronic Projects Design/Ideas/Reviews | 5 | 2nd November 2007 04:51 PM |
| Differential transformer how to measure this signal | sardineta | Electronic Projects Design/Ideas/Reviews | 18 | 7th October 2004 02:30 PM |
| wounding a transformer | farnoosh | General Electronics Chat | 0 | 6th June 2004 06:47 AM |
