Old 2nd January 2007, 10:02 PM   (permalink)
Originally Posted by NewcastleSAR
I can't seem to marry the 15VA and the output and 1A for this transformer to one at RS. The nearest I get to it is 347-2694 (16VA) but it only supplies 0.5A.
If it's like the other transformers (and I presume it is?), then it has TWO secondary windings (this make it far more versatile), paralleling them gives you the 1A you're looking for!.
Old 2nd January 2007, 10:23 PM   (permalink)
Can you recommend a good book or website location that would help me understand transformers and how to select the correct one.
Google is your best bet.
I'm still trying to tie in the values of the transformer in the circuit to understand the VAC (in/Out) versus the VA values and the output current it can supply.
VA is Volts times Amps, a 15V 15VA transformer can supply a maximum current of 1A.
In simplistic terms and at the risk of getting a smacked, with reference to the 220VAC/15VAC 1A transformer, is this essentially a transfomer that steps down 220 Volts AC to 15 Volts AC and can supply an output current up to 1 amp?
Yes
I can't seem to marry the 15VA and the output and 1A for this transformer to one at RS. The nearest I get to it is 347-2694 (16VA) but it only supplies 0.5A. The next one up is the 201-8738. Its supplies 0.73A but the VA has gone up to 22VA.
Don't worry about it 1A is far more than your PIC and optocoupler emmitter will ever use, just use the 1VA or 1.5VA unit I suggested.
In the 6V transformer circuit, is the reason for specifying the 8V (or 9V) transformer due to the 7805 regulator needing a minimum voltage of 7.5V for it to operate?
Transformers voltage are always specified as Root Mean Square (RMS), an AC voltage that will do the same work as a DC voltage.
V_{PEAK}=sqrt{2} \times V_{RMS}
The voltage across your smoother capacitor is the peak voltage minus the losses in the rectifier (1.4V).
V_{OUT}=sqrt{2} \times V_{RMS}- 1.4
Now, if you look at the datasheet for you will find that the 7805 needs at least 8V to regulate properly, therefore the output needs to be kept above 8V, so rearanging the above formula:
V_{RMS}= \frac{V_{OUT}+1.4}{sqrt{2}}
So your input needs to be above:
V_{RMS}=\frac{8+1.4}{sqrt{2}}=6.64V
Sorry if all the questions sound dumb.
I'm sorry I don't have either the time of will to explain all of this in great detail (that would take many pages).
Don't worry about the above formulae, try googling the following terms:
Voltage regulator.
Root mean square.
Dropout voltage.
Smoothing capacitor.
Transformer.
Screen name: Aloone_Jonez
Hero999 is offline
Old 2nd January 2007, 10:37 PM   (permalink)
You've not studied the circuit! - the 15V one has four seven segment LED displays, so needs a much higher capacity supply!.
Old 2nd January 2007, 11:09 PM   (permalink)
Hi Nigel..
I think things are staring to click together now.
Having just studied a transformer circuit on the Internet and applying the 15VAC value if I wire the two secondaries together in series, it doubles the voltage but keeps current at same level but wiring in paralled keeps voltage at same level but doubles current.
Is that correct?
Declan
NewcastleSAR is offline
Old 3rd January 2007, 09:18 AM   (permalink)
Hi Nigel..
Is that correct?
Yes it is, it's important though that the windings are in phase, but it's usually obvious how to do that.
Old 3rd January 2007, 12:05 PM   (permalink)
Cheers Nigel..
Many thanks for your help.
Declan
Old 3rd January 2007, 08:50 PM   (permalink)
Now this is confusing.
There are two different projects here.
Which one are you refering to?
If it's the first one "Darkroom Timer 1 6V.pdf", then I stick so what I've said.
If it's the second one "DarkroomTimer Schematic.pdf" then you're right, I have made a mistake, that tiny 1.5VA transformer just won't do.
However I do feel that 1A is still a bit overkill, those LEDs will only take 7*18.6mA = 131mA (they're multiplexed aren't they?) and I can't see the rest of the circuit using much; maybe the whole thing will use 200mA maxumum.
15V isn't needed a 12V will do.
What's the point of the opto-isolator? The relay should provide all the isolation you need.
Why bother with a separate 12V supply? You can get 5V relays you know.
NewcastleSAR,
Which project do you want to build, the first of the second?
Hero999 is offline
Old 4th January 2007, 09:15 AM   (permalink)
Assuming the figures are correct, 200mA from the 22V after rectification, is still 4.4W.
Old 4th January 2007, 11:37 AM   (permalink)
NewcastleSAR,
Which project do you want to build, the first or the second?
Hi Hero999
At present, I'm haven't decided which of the circuits I am going to build although I am leaning towards the 2nd circuit titled the 'DarkroomTimer Schematic.pdf'.
As both used transformers, my questions were related to assistance in attempting to understanding and select the correct type of transformer from RS Components.
Looking at both circuits in a simplistic manner for my brain, I see what you are saying in relation to the 12V section. Is there any particular reason why I couldn't use the PSU Section of the 6V Circuit (adjusting Transformer to suit) and also integrating the Solid State Relay S201S01 (superseded by S201S05) into circuit 2 ('DarkroomTimer Schematic.pdf') thus doing away with the 12V section?
Declan
Old 4th January 2007, 11:51 AM   (permalink)
Seeing as you're having to ask for advise on a transformer, I don't suggest you attempt redesigning the circuits!.
Old 4th January 2007, 11:59 AM   (permalink)
Hi Nigel..
Yes, I understand what you are saying and wouldn't attempt to even consider redesigning the circuit but in terms of understanding concepts, would what I said work?
Declan
Old 4th January 2007, 12:30 PM   (permalink)
Yes, the principle is OK.
Old 4th January 2007, 01:52 PM   (permalink)
Cheers for that Nigel..
This discussion has been very enlightening. I'm going to talk to the School's Technology Teacher to get further advice from him. I did electronics years ago but to be honest, the amount of maths in it put me off and being at a young age, that wasn't hard.
Now as I approach 40, I think I would be in a better 'educational state of mind' to learn.
Many thanks
Declan
Old 4th January 2007, 04:10 PM   (permalink)
Good luck! - it's EXCEEDINGLY rare to find one who knows anything about Electronics - it's usually taught by a teacher who attended a short course (1 day or something!).
Old 4th January 2007, 06:50 PM   (permalink)
But I suggested a 12V transformer.
0.2 \times \sqrt 2 \times 12 = 3.4W
So I'd recommend a 12V 300mA transformer.
That's true, I knew more than my technology at the age of 12.
I have a feeling that these circuits were designed by a PIC expert rather than an electronics expert.
Hero999 is offline
transformer question qsiguy Electronic Projects Design/Ideas/Reviews 14 7th April 2008 07:08 PM
Transformer Problems? MsStateDawg Electronic Projects Design/Ideas/Reviews 15 2nd November 2007 11:17 PM
Circuit Design: Transformer (or Inverter?) jrod5000 Electronic Projects Design/Ideas/Reviews 5 2nd November 2007 05:51 PM
Differential transformer how to measure this signal sardineta Electronic Projects Design/Ideas/Reviews 18 7th October 2004 03:31 PM
wounding a transformer farnoosh General Electronics Chat 0 6th June 2004 07:48 AM
