| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
| Does anybody have any info/datasheet/replacement on this Tr.? I've looked everywhere but haven't found anything. It's from my Phillips 3226 scope and it died out of a blue. I've found some more unlucky owners of these old but really well built instruments that have the same thing blown. | |
| I have the same problem - trigger not working on Phillips scope because of dead ON561 - but can't source new one or find equilent. Did you you find a solution? | |
| Hi, please register and try at http://www.harvare.com/sendrfq.php also you may try with RS Components of UK
| That's what leaning on schematics does to you... In fact this is not at all a double transistor, these are two separate fets thermally coupled by a piece of tin. I've even made it reading which fets these were but I've forgot it. try just removing the tin cooler and it will appear, no harm done. These FET's were just commercialy available without any fuss. As I can remember these did have somewhat higher Vds (around 30-40V). Tommorow I'll try to find it and post here. Shame, they could have said 2xFET whichever those are instead of inventing something no one can find ever and then charge fortune for it. No wonder they went down. (bought by Fluke I believe). I have a few PM 2517 4 digit DMM's that I'm sorry to throw away. Does anyone have it's schematic/manual so I could adjust it properly? | |
| I'll bet they are a matched pair, perhaps in a differential amplifier. The thermal coupling would reduce mismatching due to thermal gradients and thermal transients. Replacing them with two randomly chosen units may not be satisfactory. | |
| I have looked online for hours with no results yet. | |
| The problem with the ON561 seems to pop up at a regular rate. I must admit that I didn't pay much attention to it because I didn't understand what the problem was and I still don't. If you got a defective ON561 there's gonna be also a good half which can be used to select another fet to replace it. So build part of the circuit from the scope twice on a breadboard and start comparing the original part with a number of lookalikes which you select from the Philips program. Possible candidates are BFW10, BFW11 and 2N3823. But most of these will be obsolete so see what is still available from other manufacturers. The description of the ON561 by Panter did ring a bell, I started digging and I found two similar double fets, the ON235 and the ON384 which had it's terminals shorted by conductive straps. I also found similar double fets in a databook of 1976, the BFS21 and the BFS21A. Probably also obsolete. I'm afraid this post won't be of much help. So build the test circuit and start comparing what is still available. on1aag. Last edited by on1aag; 20th February 2007 at 09:27 AM. | |
| Some years ago I built a diff amp using 2 individual FETs. I bought 10 of the same FET and plotted the curve of each on graph paper and then used the 2 that were the best match.
__________________ Len | |
| Well, did it work? Which ones did you use? Have a Datasheet on the ones you used? How about a Schematic? | |
| There's someone else tortured by the same thing in this world. I looked in my files two days ago and i could not find the type i used. Do not worry, apparently it will appear, just if I remember. After all I still do have it's schematics so You can guess the type from there. My scope is PM 3226 double trace 15MHz If Yours is from the same family it will do. If You send me your mail, i'll scan it for You. Good luck. | |
| My email address is in every post I make hotwaterwizard@aol.com | |
| I've sent schemes to hotwater, I hope he'll post it when He gets it since I'm having trouble here for some unknown reason. Now the procedure. Make sure it is actually this FET, I'd first go to: -check BAV45, it seems critical to me, -check SG3823 and even BF 240's after, since those can pull up or sink your otherwise good signal away from being visible on screen. -although tempting do avoid just picking components from the board, it usually doesn't solve anything. Rarely I've been that lucky. This is not a differential amplifier circuit (although it basically does similar thing), so you can put the good FET on signal path and new (different) one on position set (lower) path. If they have similar thermal coefficients (T correlated Hfe rise) it's going to be OK. If you choose good, just some little trimming of, R506 for instance, will do. Good luck. You'll need it. He! | |
| Some eight Years ago I've paid dearly for a brand new gadget called Fluke Scopemeter. I gave up an arm, a leg and a portion of an eye for it. IT WORKED ABOUT SEVERAL DAYS AFTER WARRANTY EXPIRED, which meant two years from purchase. Although serviced in Fluke it just never worked reliably again. Later they said that the problem was in newly developed SMT components and gadgets inside. After I urgently have sold it , i just didn't want to be bothered again, I just got burnt too much. These two PM3226's, the old junk in my workshop were there, and on the field, for more than 25 years now, with just that one failure. The first goes everywhere with me, and the second sits in the lab. Just for laughs, I must have had about ten car crashes so far, and my father before me, who actually had bought those. I think I should actually gold-plate these two scopes. Now, I do see something newer will have to come and I wouldn't like to repeat the previous mistake. Is there anything on the market that I can trust, or should I just go for Chinese, do as it can, and not bother if it fails? | |
| PM3226 Phillips Oscope Schematics. | |
| OK, those are source followers, serving as input buffers for the input preamp. The best transistor I can find to replace them (looking at datasheets) is J310, which is made by Vishay/Siliconix, among others. You will want to rebalance the input stage by grounding the input, centering the balance A or balance B pot, and then tweaking the pot between the sources for DC centering on the screen. You might also have to tweak the trimmer cap that's to GND between the input attenuator and the gate in order to get the frequency response or step response (with no probe, or maybe a 1X probe) back to being flat. Dean Huster might be of some help in the calibration procedure if I'm wrong and you don't know how to do it. I think Dean serviced Tektronix scopes. This is a Philips, but heck, it's still a scope. EDIT: If these are too big (maybe input capacitance is too high or something), you need some with Idss > 1ma, because these run at about 1 ma each. Dean, are you out there? Last edited by Roff; 27th February 2007 at 04:29 AM. | |
| Double sided copper boards | Screech | General Electronics Chat | 10 | 26th February 2007 09:02 AM |
| Lighted LED double kick bass pedal??? | moody07747 | Electronic Projects Design/Ideas/Reviews | 6 | 14th January 2007 09:26 PM |
| Transformer safety | Dr.EM | Chit-Chat | 21 | 8th November 2006 03:12 PM |
| Double the frequency of pulse/charge in DC circuit | bcunney | General Electronics Chat | 2 | 13th December 2005 12:34 AM |
| Difference between double sided PCB and 2 layer PCB | darvaish | Electronic Projects Design/Ideas/Reviews | 2 | 10th March 2005 06:32 PM |
