| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
Friends:
Where do you all look on the internet to find a circuit diagram? I need a simple diagram for a push switch that when I push it once it closes a switch and keeps it closed until I pulse it again (think of spring loaded switch that always disconnects when the presure is released). One pulse turns on an LED circuit and another turns it off. The switch must run off 3, 6 or 9vdc. Thanks amigos! Migs
"Sometimes we forget that the world itself is paradise." Douglas Coupland, 'Microserfs' "We either make ourselves miserable, or we make ourselves strong. The amount of work is the same." – Carlos Castaneda "One single grateful thought raised to heaven is the most perfect prayer."- G. E. Lessing |
Hi Migs,
Is this the kind of circuit you were looking for ? on1aag. |
More. Several different circuits.
Hi on1aag and hotwaterwizard:
Thanks for these schematics, I will analyze them and get back to you if I dont understand. on1aag: What are the "S" Items in the schematic? Thanks amigos!!! -Migs
Hi Migs,
The CD40106 is a hex inverter, the "S" is not an "S". It's the symbol that means that these inverters have Schmitt-trigger inputs. With kind regards, on1aag. |
Hi on1aag:
I would have to use 6 CD40106's for the switch? The symbol on the right is a LED? Thanks amigo! Migs
The CD40106 is a HEX inverter. HEX means six. It has the six inverters inside. Lookup its pin numbers on its datasheet.
Yes, the LED symbol is an LED, the resistor symbols are resistors and the capacitor symbol you will have to guess what it is. I recommend using a battery or power supply for the circuit.
Uncle $crooge |
Why bother, when you can buy switches that will already do this?
Uncle $crooge |
just use a "touch switch" like this: http://www.electronics-lab.com/projects/sensors/024/
No moving parts! Easy to modify for other voltages. Cool no?
If is too complicated.....most of the times is the wrong way. |
Tarsil:
Do you know of a circuit like the one you showed that latches the switch closed until the next press? Migs
Uncle $crooge |
| PIC Switch Management Techniques | Mike, K8LH | Micro Controllers | 2 | 28th September 2006 12:33 PM |
| pulse on, pulse off latching switch | b1mmuo27 | Electronic Projects Design/Ideas/Reviews | 15 | 23rd November 2005 01:18 AM |
| voltage modification... newbie question, please help!... | catboy | Electronic Projects Design/Ideas/Reviews | 9 | 19th September 2005 02:40 PM |
| Newbie - Simple Light Switch | sroussie | Electronic Projects Design/Ideas/Reviews | 2 | 6th March 2004 12:48 PM |
| Newbie question about transmitters | dcoleman | General Electronics Chat | 1 | 5th August 2003 04:59 PM |
