Old 15th September 2006, 10:30 AM   #1
Default Part number of flip-flop IC
Can I know what's the part number of these flip-flop ICs?
R-S
J-K
D
I couldn't find them from the Google..
bananasiong
bananasiong is offline
Old 15th September 2006, 05:16 PM   #2
You don't say if you want power hungry TTL logic or low power Cmos.
I have The Cmos Cookbook so I just look them up. I used to have The TTL Cookbook but don't use old TTL anymore.
The are lists of logic ICs on the web somewhere.
audioguru is offline
Old 15th September 2006, 06:24 PM   #3
Grab this Logic selection guide from Texas Instruments:
http://www-s.ti.com/sc/psheets/sdyu001y/sdyu001y.pdf
Skim through the first 50 pages to make sure you know which logic family you need, and skip to page 113 for the actual flipflop tables.
hjames is offline
Old 16th September 2006, 09:33 AM   #4
I don't know what type.. Just for experiments, I think should be the cheapest type. It is because when I buy it, I need to have the IC code, the seller won't get me the IC if I just tell him "I want a SR flip flop".
p/s: thanks hjames for the pdf
bananasiong
Old 11th October 2006, 12:49 AM   #5
http://rabbit.eng.miami.edu/info/datasheets/
Common JK is the 7473... common D 7474 (though of course there are plenty of variations to choose from... and I'm only talking about TTL here).
oticon6 is offline
Old 11th October 2006, 02:02 PM   #6
Default MM74hc273 Octal D-Type Flip-Flop with Clear
Maybe useful for you? look to datasheet
http://www.alldatasheet.com/datashee...MM74HC273.html
vedo35 is offline
Old 12th October 2006, 03:16 AM   #7
Thanks! Can anyone tell me what is open collector? Does it mean that I need to connect a supply through a resistor to the collector, then the output is between the resistor and the collector?
i noticed that the 7401 and 7403 are the same, 4 input nand gate, open collector, is there any different between them?
bananasiong
Old 12th October 2006, 03:33 AM   #8
Does anybody remember old TTL ICs? I used them in the 70's. 30 years ago!
Old 12th October 2006, 09:32 PM   #9
74LS279 R-S FlipFlop
74LS107 J-K Flip Flop
74LS109 J-Kbar FlipFlop
74LS74 D Flip-Flop
Papabravo is offline
Old 13th October 2006, 05:13 AM   #10
I used SUHL in the '60s. I also used some RTL and DTL logic families before that. Of course, you guys already know that I'm older than dirt.
Ron
Roff is offline
Old 13th October 2006, 05:21 AM   #11
In the 60's I bought some RTL ICs and serviced an office accounting computer that was full of DTL. It had core memory with hundreds of little ferrite doughnuts. Its operating system was punched cards. It was a huge automated typewriter!
Old 20th November 2008, 01:55 PM   #12
Hello
Sorry to revive an old thread but I have a question about the 74LS279 R-S FlipFlop.
Here's a data sheet of the thing: http://focus.ti.com/lit/ds/symlink/sn74ls279a.pdf
Notice how the logic diagram for RS latches 1 and 3 have two ~S inputs (~S1 and ~S2).
I don't need two inputs on the latch so what can I do to ~S1 and ~S2 to make them work as just one input. (I tried simply tying them together, didn't work!)
Actually if anyone knows of a different SR Latch IC that would be great (possibly one without inverted inputs)
mrlooneytoon is offline
Old 20th November 2008, 02:40 PM   #13
Hi Mrlooneytoon,
Tying them together should work but if it doesn't you
could connect the unused set inputs to +5 volt.
on1aag.
on1aag is offline
Old 20th November 2008, 02:47 PM   #14
Originally Posted by on1aag View Post
Hi Mrlooneytoon,
on1aag.
Hi
I connected one of the unused inputs to 5V through a 10K pullup. Seems to do the trick.
Thanks for your help on1aag
flipflop, number, part
