Old 19th August 2006, 04:53 PM   #1
Default equivalent for an IC
can somebody help me with the equivalent of DS275 Ic.
schematic , pin diagram attached
im planning to build a programmer for 89c51/52
http://chaokhun.kmitl.ac.th/~kswichit/easy2/easy2.htm
DS275 is not available and im running short of time as my last date for submission of project is too near. help would be greatly appreciated
impossible says i'm possible
desperadogear is offline
Old 19th August 2006, 05:45 PM   #2
Look at the links on the page !
1Steveo is offline
Old 19th August 2006, 06:06 PM   #3
A pin compatible part probably isn't available - Dallas semi got acquired by www.maxim-ic.com, and unless you want to try getting a sample directly from them, it's probably easier to work around it.
Use a more standard MAX232 chip (google and you'll find a lot of schematics)
Or look in the http://www.electro-tech-online.com/electronic-projects/ section of the forum for Mike's "Simple RS232-to-TTL Adapter". It's two transistors and a couple resistors and would probably be a functional replacement for the chip.
James
hjames is offline
Old 19th August 2006, 09:39 PM   #4
thanks a lot hjames. That answers my question
Old 31st October 2009, 03:19 AM   #5
I'm looking for a complete on line IC cross ref equivalents list.
For instance - to find an equiv for an MLM324 quad opamp -
Sounds simple enough doesn't it.
Ron2 is offline
equivalent
