| Datasheet/Parts Requests Request a datasheet or enquire about part equivalents and/or difficult-to-find parts here. |
| I need to control the cutoff frequency for several LP filters independently. Their cutoff frequency 1/100th of the input clock frequency. I need to try and find an oscillator/clock generator (preferably multiple clock signals in a single IC) that can go 100Hz and up (with max of 500kHz, but this maximum can be much MUCH MUCH MUCH lower). It needs to be programmable without external resistors or capacitors (I need the MCU to be able to control the frequency). Anyone know of such a software-programmable low-frequency multiple-clock generator? | |
| There are probably as many options as there are cross ties on the railroad tracks. The microprocessor itself is a candidate for producing a variable clock output. That output can feed a bank of flip-flops or counters which will provide outputs until the cows come home. There are also numerous serially programmable frequency synthesizers that cover DC to blue light. The challenge is not in the minimum or maximum frequency but in the step size or granularity of the frequencies you want to produce. | |
| Can a 50% PWM pulse be used as a clock? | |
| Why does it seem like a waste? TO me it seems like the ultimate in flexibility...although you are wasting an MCU if that's what you are referring to. | |
| Yes but using the PWM output can really limit your choice of frequency. I think it is better to create your own output based on loading a timer to a sepcific value with an auto reload and an output toggle. | |
| Oh, that's what I meant. Using PWM generated in software by an MCU. I have also noticed that PWM modules have a small range of frequencies. | |
