Old 15th March 2006, 03:27 PM   (permalink)
Default Sorta a backwards request....
Ok, this'll seem weird... But does anyone know of a cheap opamp that's got a ton of distortion? You know, sort of a "you get what you pay for" kinda thing.
I'm buildin' a custom fuzz box, and can't exactly afford to test a bunch of über-cheap amps... (yeh, I'm that strapped...)
Lupin Forius is offline
Old 15th March 2006, 03:50 PM   (permalink)
You don't get the distortion from the opamp, you get it from overdriving it and clipping against the supply rails, or by clipping with diodes. So any opamp will do (assuming you want to use an opamp?), just pick a cheap one as there's no need to spend more than you need!.
Old 15th March 2006, 04:38 PM   (permalink)
Heh... guess that'll work. Although, I do know that there're opamps that're sold with "low distortion" as the sales-pitch. And I mean from major companies who would otherwise have no trouble selling their products, without using false claims...
I do thank you for yer tip, though
Old 15th March 2006, 04:52 PM   (permalink)
Yes, but you're talking VERY low distortion, even the 'poor' ones are very good anyway (if used correctly), none are high distortion.
Old 17th March 2006, 02:39 AM   (permalink)
Transistors.... Now there's an idea. And luckily, I have a bunch of "junk" lying around collecting dust, just full of transistors, some more than 20 years old. I know how to test the things... Hmm... *thinks*
Thanks.
Old 31st March 2006, 05:52 PM   (permalink)
Truth, ANY opamp will do.
I had great results building an Distortion option on a Guitar Tone Control I built. (Fit inside the body)
I used a DUAL AMP, LF353. It had an Input buffer, 2 part Tone Controls followed by an output amp after the controls. By adjusting the feedback loop on the INPUT amp (IE: Variable resistor between op amp out and the Inverting input pin) I could easily overdrive the signal so it had superb distortion.
Pete
pwillard is offline
Old 1st April 2006, 03:04 PM   (permalink)
Lupin, if companies made distortion-only amplifiers, you would be their only customer :lol:
why? because most people want to avoid distortion.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
