Old 2nd March 2006, 06:37 PM   #1
Default Ultrasonic Transducer
Could anyone plz give me details of the GL sensor numbered
GL 40T-16F/16S
This is an ultrasonic transmitter-receiver pair tht i found in a shop.. But i have no details abt it.
rcd316 is offline
Old 28th June 2006, 05:08 PM   #2
can anybody tell me how to use GL 40T-16F/16S
headcracker is offline
Old 3rd July 2006, 02:10 AM   #3
A picture would help.
Having trouble finding info on it.
John DeRosa (Hotwaterwizard)
hotwaterwizard@aol.com
hotwaterwizard is offline
Old 3rd July 2006, 02:41 AM   #4
here is a gif image of the datasheet
Old 3rd July 2006, 08:27 AM   #5
GL 40T-16F/16S
Ask the shop for details. they must have them.
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 5th July 2006, 02:04 AM   #6
they usualy transmit and receive in the 40 khz range,Radio Spares used to list them.
oldtimer is offline
Old 1st April 2007, 04:53 PM   #7
Ultrasonic Air Sensors, Air Transducers
This is kind of piezo-ceramic transducer with high sound pressure level, high sensitivity. The figures are relatively higher than the products of other suppliers. Intruder alarm system for car, remote controllers, objects detectors are the major applications. Open type with small size. Ultrasonic sensor selection chart for the code of standard model number.
Specifications:
Sound pressure level: 0dB vs. 0.0002Mubar. Measured at 10V RMS, 30cm distance.
Sensitivity: 0dB vs. 1V/Mubar.
Features:
Guaranteed high quality sensors
Competitive price
Timely delivery
Stringent QC
High S.P.L.
High sensitivity
Low consumption
High efficiency
Pest repellers, animal repellers, remote controllers, intruder alarm system, flowmeters, level controls, powder sensors and object detectors.
Welcome for customer design and OEM:
Air transducers: 20-250Khz range for special design
others, such as: actuators, sensors, humidifies, scalers and fish finder...etc.
No. (cover page) Parts number Nominal frequency Sensitivity Sound pressure level Capacitance Diameter Pin diameter Pin distance Pin length Case length
A-1 40T/R-10P 40KHz -70dB min 112dB min 1700pf 9.9mm 0.7mm 5.0mm 6.9mm 6.9mm
A-2 40T/R-12B 40KHz -67dB min 114dB min 2000pf 12.6mm 0.7mm 8.5mm 6.2mm 9.4mm
A-3 40T-16F 40KHz -65dB min 120dB min 2000pf 16.1mm 1.0mm 10.0mm 9.5mm 12.0mm
A-4 40T/R-18E 40KHz -70dB min 120db min 2000pf 16.1mm 1.0mm 10.0mm 9.5mm 12.0mm
jokie is offline
Old 22nd April 2009, 05:18 PM   #8
what about the range of this pair?
40T-40R
In my project , i employed this component but the receiver is not working properly.
Noise is more and not catching the signal transmitted.
Any suggestions? Plz help
Also could you plz suggest a method to check this pair.
Manu Tom
thommichhan is offline
Old 8th November 2009, 07:31 PM   #9
can any one send me a pdf about ultrasonic transducer
asma is offline
transducer, ultrasonic
