Old 18th February 2006, 07:43 AM   (permalink)
Default Guitar amp IC
I have a Guitar amp that has two DIP8 ICs Which read:
458DD
JRC
5185B
What IC is equivalent? I have some OPA2132P, will that work?
Fletcher is offline
Old 18th February 2006, 09:16 AM   (permalink)
Default Re: Guitar amp IC
458DD
JRC
5185B
Generally twin-opamps use the same pin connections, so you should be OK.
Are the opamps faulty or something?.
Old 18th February 2006, 12:35 PM   (permalink)
There was no sound at all. Ive replaced them and it seems to work now, although now there is a terrible buzz which i cant seem to get rid of.
Fletcher is offline
Old 18th February 2006, 12:39 PM   (permalink)
Randomly replacing parts isn't a good method of fault finding, you need to trace the signal (or inject a signal) to find what's happening, and take voltage measurements to see what's wrong.
Opamps are VERY reliable devices, it seems extremely unlikely that two would fail? - unless something nasty has happened? (like too much supply voltage?).
Old 31st March 2006, 06:04 PM   (permalink)
Yes, and the him/buzz you hear may have a LOT to do with why the original amps failed. Hum is normally eliminated by employing filter capacitors and good grouding.
How old is the unit? There is a chance, if the amp has been sitting idle for a long time in less than ideal conditions (a grarage), you have large filter capacitors with dried up electrolyte. This is a common repair on antique radios, for instance.
How much have you checked? Voltages? Cold Solder joints? etc...
PW
pwillard is offline
