Old 29th December 2005, 10:53 PM   (permalink)
Default Fast Optoisolator
Anyone know of a optoisolator suitable for this:
input voltage <= 5v
output supply >= 5v
output voltage >= 5v
output current max >= 10 mA
output rise time <= 1 microsecond
operating temp <= -20C to >= +80C
This is for ground loop isolation for the gate of an International Rectifier ISP0551T MOSFET switch.
ezombie is offline
Old 30th December 2005, 12:03 AM   (permalink)
I think I found something that might work:
Sharp PC942J00000F
http://document.sharpsma.com/files/pc942_ej.pdf
Air conditioning controller, go fig. Non-inverting 5V output, 5.4V-13V supply, 600mA output current, 5kV isolation, 200uA leak, 1uS max rise and fall time, -20C to 80C temp range. At a supply current of only 20Ma max, I'll just use an IC wide range 7.5V voltage regulator.
ezombie is offline
Old 30th December 2005, 03:48 PM   (permalink)
Default Re: Fast Optoisolator
Originally Posted by ezombie
input voltage <= 5v
I think all optoisolators meet this requirement
output supply >= 5v
Active devices don't supply power by themselves.
and I think output supply and output voltage are the same (unless in your case, supply = current or power)
Think of the output as a logic gate, where one pin is connected to +ve, and the other, output.
I think a gazillion of them meet 10mA, but how high do you expect?
Maybe you should look into optoisolators more.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 30th December 2005, 05:45 PM   (permalink)
I'm going to try the Sharp one for now, but it's a brand new part and a little hard to get.
I ran through all of digikey's offerings, but most aren't that fast (<1uS rise time), or can't handle that much current draw on their output.
ezombie is offline
