Old 17th December 2005, 12:50 AM   (permalink)
Default transformer help
hi all,im using an audio transformer for my high voltage project as i need it to be quite small,its a mini transformer lt44 which i got from maplins,it has a primary dc resistance of 100ohm and secondry of 1kohm i would like to step up the voltage further so could anyone suggest a transformer with an even higher secondry resistance and where i could buy one of these,the primary will be taking 200v to 300v pulses,thanks
paulyt5966 is offline
Old 18th December 2005, 02:58 PM   (permalink)
Default Re: transformer help
The DC Resistance doen't mean much of Anything in your application.
Neither does the Impedance between primary and secondary.
Its the Turns Ratio that is Important.
You are using an AC Signal, Not DC.
Although it may appear that the 1000 ohms is 10 times more than the 100 ohms, the two windings are probably different wire gauges. Therefore you have no idea of the actual turns ratio.
Without knowing What circuit your are using, your best bet is to use a Ferrite core and Wind your own transformer.
If I saw your circuit, I could possibly advise you better.
Merry Christmas.........Gary
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 18th December 2005, 09:31 PM   (permalink)
i will try and draw a picture of the circuit and post it when i get a minute,thanks.
