Hi, Can you tell me which Orcad version are you using. The best way to solve these problems are to upload your files and the calculation made.
Please can any one help me in simulating an oscillator in orcad. I have designed an oscillator using opamp but its not working. i have als applied the initial conditions also but still its not working.
Sometimes to get a oscillator started in simulation you need to add a little perturbation to simulate the noise in a real circuit. One way to do that is to add a short single pulse of current to the oscillator loop using a current source. (Don't use a voltage source since that will short the loop to ground.)
Zapper
Curmudgeon Elektroniker
--Inside every little problem is a big problem trying to get out.--
If it is "not working" - perhaps it is not really an oscillator, which means: Does the circuit meet the oscillation condition (Barkhausen)? Show us your circuit diagram and you will get a definite answer.
Regarding Chrutschow`s remark: It is correct - however, of course you can also use a short voltage pulse, if it is applied to any node that is already grounded.
Absolutely serisous, I understood it as applying voltage to a node that IS grounded. I think saying "... that was initially grounded" would be a lot clearer.
Was this really your understanding? I suppose you were able to read between the lines. I am not silly enough to connect a voltage source between ground and ground. But it seems that my knowledge of the english language should be improved.
Nevertheless - thanks for replying.
Attach the circuit. It will help
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Need help! Regarding an oscillator output circuit design.. | menirva | Robotics & Mechatronics | 7 | 25th November 2007, 10:51 AM |
| Need Help with Oscillator Circuit | headbuttking2 | Electronic Projects Design/Ideas/Reviews | 15 | 4th May 2005, 09:53 PM |
| Need help with Oscillator circuit | headbuttking2 | General Electronics Chat | 1 | 1st May 2005, 09:09 AM |
| i have Problem on Orcad. need help~~~~ | wontall | General Electronics Chat | 1 | 7th May 2004, 07:39 PM |
| I need help in designing a CMOS Relaxation Oscillator .... | issam | Electronic Projects Design/Ideas/Reviews | 1 | 4th January 2004, 04:33 AM |
