Eagle traces and pads not that smooth
123 Last »
  1. #1
    mradel1984 mradel1984 is offline
    Hi There
    I'm new to eagle and I am using Eagle Ver 5.6.0
    When I try to save my layout into pdf format using the print command I found some artifacts like those shown in the next test layout picture taken from the pdf file
  2. #2
    ronsimpson ronsimpson is offline
    I have not used 5.6.0.
    The problem may be in the PDF. Is there a higher resolution option? If you converted to PDF at 150dpi it will look bad. Try 1200dpi.
    +1
  3. Thread Starter #3
    Quote Originally Posted by ronsimpson View Post
    Hi ronsimpson ,
    I don't see any resolution or quality options in the pdf create dialog, just paper size A4,A5,.. and other non-important options
    btw , could you tell me your version number , and whether it produces smooth traces or not ?
    Thanks in Advance
    0
  4. #4
    The output resolution depends on what I print to. If I make a gerber file and view it things look good. If I look at a paper plot is is only good to what the printer will do. Eagle crashes on this machine so I will look at it in a different machine in the morning.
    0
  5. #5
    kubeek kubeek is online now
    I always thought that eagle exports to pdf in vector graphics and not in raster, so there should be no artifacts whatsoever.
    What do you see when you zoom way in?
    0
  6. #6
    jpanhalt jpanhalt is offline
    None of the Eagle versions, up to 6.1 export pdf so far as I know. My versions export png, some bitmaps, and tif.
    John
    0
  7. #7
    3v0 3v0 is online now
    Coop Build Coordinator
    Quote Originally Posted by jpanhalt View Post
    John
    Under print you can choose to save it to a pdf file.
    0
    BCHS/3v0's PIC C18 Tutorials
    Mondo Tech's Super Probe
    Brian Schmalz's USB Bit Whacker
  8. Thread Starter #8
    Quote Originally Posted by kubeek View Post
    If I understood your question well :
    I see the same artifacts with the same degree as without zooming(artifacts are not magnified)
    Somebody told me that this is normal and they won't appear when they're printed out , is that right?
    AnyWay, is that problem common or just me . I searched the internet and I didn't find any similar problems, anybody here used eagle to export to a pdf ?
    Any recommendation for any PCB layout software that works fine regarding my problem ?
    0
  9. #9
    Quote Originally Posted by mradel1984 View Post
    Yes, EAGLE.
    As everyone has tried to point out, you are witnessing an artifact of your screen resolution or your printer resolution.
    EAGLE will work fine down to the limits of current PCB production.
    John
    0
  10. #10
    I print eagle files to pdf all the time and never had any problem with it. When you zoom in a lot you should see just straight lines and polygons with no artifact.
    What pdf reader are you using?
    0
123 Last »
How to test and ensure whether that a phototransistor is in good or poor condition ? xiaobai00 Electronic Projects Design/Ideas/Reviews 1 28th August 2007, 11:54 AM
Eagle: making small pads 3v0 General Electronics Chat 8 30th March 2007, 12:57 AM
3 Traces between pads ? 3v0 General Electronics Chat 25 23rd March 2007, 12:19 AM
12f629 - int on pin change, and tmr0 not working together... SnM Microcontrollers 7 16th November 2004, 07:30 PM
AND, OR, NOT Logic Gates Help LiquidOrb24 General Electronics Chat 5 9th February 2004, 03:42 AM
Page Time: 0.09959 seconds      Memory: 7,722 KB      Queries: 17      Templates: 0
