Help with MPSA
  1. #1
    benq1117 benq1117 is offline
    Help with MPSA
    Can someone please send me the library file for MPSA42 and MPSA92 transistors in EAGLE
  2. #2
    Reloadron Reloadron is offline
    You would do much better starting a new thread in the Circuit Simulation & PCB Design forum section.
    Ron
    0
    Please do not PM me with forum related questions. Let's keep things in the open forum. Thank you.
  3. #3
    jpanhalt jpanhalt is offline
    Those are just NPN in TO-92 cases. With the flat facing you, the pin order from left to right is EBC. You can use any other transistor with the same case and pin order, such as a 2N3904. That transistor is in the transistor, small-signal library. Then just use the value button to change the name to MPSAxx. You will get a message that it has no definable value. Just ignore that and proceed. If you are going to be using it frequently, then you may want to add it to your personal library.
    If you come across variations, keeping hunting until you find one that is right for you. I keep both generic EBC and CBE TO-92's in my personal library.
    John
    0
    Last edited by jpanhalt; 1st April 2012 at 12:50 PM. Reason: added variation comment
  4. Thread Starter #4
    Thank you!!
    I have tried renaming BC337 from the transistors npn library with MPSA42 will that work?
    Also MPSA92 is a PNP transistor so wich transistor can I rename ?
    0
  5. #5
    Oops, sorry about that. I was sleepy eyed when I looked up the MPSA92. In any event, the principle stands.
    The BC337 has the wrong pin order. Try this site to look up the pin orders and datasheets: http://www.alldatasheet.com/view.jsp?Searchword
    Have to run out for a few hours. Try the PNP 2N3906...I just don't have time to check it right now.
    John
    0
  6. #6
    ericgibbs ericgibbs is offline
    Super Moderator
    Quote Originally Posted by benq1117 View Post
    Thank you!!
    You may find these images helpful.
    0
    "Nigels Asm tutorials:" www.winpicprog.co.uk/
    "Ian Rogers 'C' conversion of Nigels Asm tutorials:" http://www.electro-tech-online.com/c...torials-c.html
Help with thermistor and hot/cold alarm. JB_ Electronic Projects Design/Ideas/Reviews 12 11th July 2004, 06:50 AM
Help with College Homework Rhino General Electronics Chat 3 3rd January 2003, 03:01 PM
help with a capacitor!!!!!!! bogdanfirst General Electronics Chat 9 26th December 2002, 02:55 PM
HELP WITH APPLIANCE AND PARALLEL PORT LARRYV General Electronics Chat 2 16th November 2002, 04:07 PM
Help with AND gate Switching TheFox Electronic Projects Design/Ideas/Reviews 4 18th September 2002, 05:43 PM
Page Time: 0.07109 seconds      Memory: 7,430 KB      Queries: 17      Templates: 0
