Valve Rectifier Model
  1. #1
    linguist linguist is offline
    Hi All,
    Could some give me a hand at adding a heater filament to the GZ34 tube rectifier in LtSpice.
    Just can't seem to work it out?
    I can run the GZ34 rectifier in the program but have insufficient knowledge to add the heater filament & get it to simulate correctly.
    I have added & attached what I have.
    The GZ34 Symbol & Model & the PSpice Heater Model, the GZ34 Datasheet.
    .SUBCKT GZ34 1 2 3
    * A1 A2 C
    X1 1 2 3 VALVE1 G=3.924m
    .ENDS
    PSpice model of Heater:
    * Vacuum tube heater PSpice Model 9/96, Rev. 1.0 (fp)
    * This model is provided "as is", with no warranty of any kind,
    * either expressed or implied, about the suitability or fitness
    * of this model for any particular purpose. Use of this model
    * shall be entirely at the user's own risk.
    * For a discussion about vacuum tube modeling please refer to:
    * W. Marshall Leach, jr: "SPICE Models for Vacuum-Tube Amplifiers";
    * J. Audio Eng. Soc., Vol 43, No 3, March 1995.
    * This model is valid at the following conditions:
    * - Indirectly heated, oxide coated cathodes only;
    * - Tungsten wire, Tnom=1400..1500K (cathode T=1050K);
    * - Heater warm-up time=11s.
    * This heater model can be operated either at AC (any waveform), DC
    * or any combination thereof, just like a real heater. VNOM and INOM
    * are the nominal operating voltage and current of the heater
    * respectively. If many heaters are connected in parallel, set INOM
    * to the sum of all heaters' currents. These parameters are passed
    * to the model in the following way:
    * X1 Va Vb Heater params: VNOM=6.3 INOM=4.8 *(4x6L6+4x12AX7A)
    * X2 R1 R2 Heater params: VNOM=5.0 INOM=1.9 *(1x5AR4/GZ34)
    .SUBCKT Heater f1 f2 params: VNOM=6.3 INOM=300m
    Grms 1 0 VALUE={1E-3*(V(f2,f1))*(V(f2,f1))/(VNOM*VNOM)}
    Rt 1 0 1k
    Ct 1 0 9.94m
    Gf f2 f1 VALUE={V(f2,f1)*1.16*INOM/(VNOM*(PWR(V(1),0.3)+0.16))}
    .ENDS Heater
    GZ34 Symbol attached, I can add in the heater filament to the symbol but not sure how to do the rest?
    Can someone help me out with this as I would like to try to simulate this correctly.
Motorcycle Rectifier tester, need design help Lucky Electronic Projects Design/Ideas/Reviews 17 22nd June 2003, 12:49 AM
rectifier bogdanfirst Electronic Projects Design/Ideas/Reviews 4 11th May 2003, 04:01 PM
How do I remove the ripple from my bridge rectifier ed sparks General Electronics Chat 5 5th May 2003, 05:11 PM
model rocketry staging timer/altimeter for cpr system needed camacazi Electronic Projects Design/Ideas/Reviews 0 18th March 2003, 09:14 AM
Older model of the KENWOOD CD CHANGER for the car boot Peter Datasheets, Manuals or Parts 0 30th December 2002, 10:31 AM
Page Time: 0.04789 seconds      Memory: 7,122 KB      Queries: 17      Templates: 0
