How to avoid very thin lines appears in the pour copper ?
« First 1234
  1. Thread Starter #31
    PCBWING PCBWING is offline
    Quote Originally Posted by ronsimpson View Post
    And unlike water electrons move pretty fast.
    At RF and where reflections are a problem, corners are a problem. Many PCB manuals say not making 90° angles because of etching undercutting. They like two 45° angles. Many people rally avoid greater then 90° angles.
    The "spaghetti" layout above reminds me of when we used to do layouts by hand with red and blue tape, (black flexible tape). I have not seen much of that in modern history.
    Yes, I remember that. But now some of the CAD software can support the curve.
    0
  2. Thread Starter #32
    Raster or Vector
    Quote Originally Posted by jpanhalt View Post
    If that comment is in response to my comment immediately above, then NO, I am not talking about the cross-hatch or lines fill (not available on Eagle) options. If you think of the fill as a vector rather than bit map, the fill is with lines that touch. The thicker the line, the more jagged will the edges be. The thinner the line, the more processing it takes. Eagle used to have a warning to that effect. Line width does not affect the gross appearance of the filled areas in Eagle, unless you pick the cross-hatch option.
    Just to clarify, there are multiple ways to do what you asked in your first post. Your later post on page 2 illustrates one of the problems of using isolate as the variable. Of course, you can avoid that by using multiple polygons. The restrict method avoids that too, and I find it easier to do in a controlled and precise manner. In Eagle, isolate and line width can affect other things too, like the the way thermals are made.
    Finally, as to the patch of copper that is not connected to anything, that is called an "orphan" in Eagle. You can choose to have them left in place or removed.
    BTW, Are you actually a PCB manufacturer or is that just an avatar you like?
    John
    I did a test. The vector sample would export a larger size Gerber than the raster sample.
    I attached the images of it.
    Filename size date time
    Raster.gbr 17,937 2012-03-29 11:22
    Vector.gbr 67,088 2012-03-29 11:22
    0
« First 1234
16F628, how to get very low power consumption?? Mr RB Microcontrollers 6 15th September 2009, 06:50 AM
How to punch out thin metal stevef22 General Electronics Chat 14 14th September 2007, 02:00 AM
How to get very fast ATD readings???? cubdh23 General Electronics Chat 2 21st July 2004, 08:38 AM
How To Make Very Small Transmitter ? Bertone General Electronics Chat 3 4th July 2003, 05:58 AM
how to avoid heating of mosfet abhay General Electronics Chat 1 5th January 2003, 05:43 PM
Page Time: 0.05099 seconds      Memory: 7,227 KB      Queries: 17      Templates: 0
