Open the following file, using a text editor and paste the model details listed below, into the
C:\Program Files\LTC\LTspiceIV\lib\cmp\standard.bjt
Paste it at the top of the other transistor models in that file, Save the standard.bjt file.
Run LTspice and using F2 , select a 'npn' transistor an place the symbol on your circuit.
Right click on the transistor symbol and then 'pick new transistor button', your NEW transistor 2N3393 should appear, select it.
I have a asc file and image to help you test , AFTER you have added the new model.
.MODEL 2N3393 NPN(IS=12.03E-15 ISE=8.195E-12 ISC=0 XTI=3 BF=154.1 BR=4.379 IKF=0.1072 IKR=0 XTB=1.5 VAF=37.37 VAR=12.5 VJE=0.65 VJC=0.65 RE=0.1 RC=1 RB=10 CJE=8.307E-12 CJC=5.777E-12 XCJC=0.75 FC=0.5 NF=1 NR=1 NE=1.971 NC=2 MJE=0.384 MJC=0.3199 TF=385.4E-12 TR=783.8E-12 ITF=0.17 VTF=3 XTF=8 EG=1.11 KF=1E-9 AF=1 VCEO=25 ICRATING=500M MFG=NSC)
